Home > Puma (Tdci) > Had to happen sooner or later.............. |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
The AA man arrived and after a while managed to get his diagnostic gear to work with my defender. Fault code "P1169 Fuel Rail Pressure Sensor in range but high" registered. Checked voltage at sensor all ok and went for a test drive and engine management light went out. He was unable to fix fault or recover me to dealers as the defender is too heavy and they dont tow 4x4, but followed me there and run me home.
I have come across this fault before in the forum with no follow up as to the outcome. Could this be a faulty sensor or is it something to do with the ecu recall. I also got him to leave the fault code in so the dealer has it. Any ideas? |
24th Oct 2010 3:03pm |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 |
I got a P1169 fault code a few times last year, and on each occasion about half a mile from my house and when the weather had just turned a little bit colder. Mine was fixed by the Q068 patch. Yours being newer it should have this update, but checking that it has the latest update should be the first thing that the dealers do. Peter
2008 SWB Truck Cab 1952 80" Soft top |
24th Oct 2010 3:25pm |
Cheers for the info MrFlips. will call the dealer in the morning and see what he says. Going to add Bell Auto Services Faultmate FCR to my Xmas list as if i had known what the fault was i could have just taken it in to the dealers instead of calling out LR assist!!!!
24th Oct 2010 3:31pm |
Just got the landy back from dealers. They replaced the manifold assembly including the sensor.
Parts LR006865((P) MANIFOLD ASS) 1 £173.25 Asked them to make sure that all recalls were done and was informed that they had been done and as a footnote added that this is not the first defender to have this fault fixed under warranty. Anybody else had this done? |
26th Oct 2010 6:20pm |
