Home > Wheels & Tyres > ZUs, Mach 5s, Predators, SVX, Boosts
Page 2 of 2 <12
CR
Ireland 2011 Defender 110 Puma 2.4 CSW Santorini Black
stt but you will need to buy ear muffs !
what about Kumho ROAD VENTURE MT KL71
Post #435127 1st Jul 2015 6:35pm
RRUK
Can someone explain the offset on alloys?
Looking at John Craddock's site they list loads of alloys and the offset they state ranges from 11mm on a 16x7 Black Zu wheel, to 38mm on a 16x8 Zu.
Is the offset the measurement of how far out from the hub the wheel extends?
So, would this mean the 16x8 Zu wheel will fill out the arches more? 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #435244 2nd Jul 2015 9:32am
K9F
Basically yes! Thumbs Up
Go Beyond wrote:
'ET' is the offset - below is from a Google search:
Offset
Alloy Wheel Offset (ET) Explained:
This is important if you are thinking of purchasing aftermarket alloy wheels. The offset is the distance in mm between the centre line of the wheel rim, and the line through the fixing (hub) face. You can have positive (+), negative (-) or neither (0). The first important reason offset is so important is that it is ultimately responsible for the position of the wheel under the wheel arch. Get it wrong and your wheels can scrub against the bodywork, suspension or at worst not turn at all! Secondly it determines how the suspension and self-centering steering behave. The most obvious problem that will occur if you get it wrong is that the steering will either become so heavy that you can't turn the steering wheel, or so light that you need to spend all your time keeping it in a straight line.
Example:
A Citroen Saxo and a Ford Fiesta have the same stud pattern, so in theory a Fiesta wheel will fit a Saxo wheel and vice versa right? Wrong. Although both cars have a positive offset the Saxo’s is very low at around ET15 and the Fiesta’s is higher at around ET38. This means that the hub mounting face on the Saxo’s wheel is closer to the centerline of the wheel and the Fiesta’s is closer to the outside of the wheel (roadside).
In a nutshell you need an offset as close to the vehicles original wheel offset as possible.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #435249 2nd Jul 2015 9:47am
RRUK
Cool, OK, I get it now.
Annoying when listings for allows don't state the offset, the sawtooths on JC's site don't mention it... 2016 D4 HSE
Post #435254 2nd Jul 2015 10:08am
rory_mcw
We have black sawtooth's on my dads 90 with 285/75/16 bfg m/t's
I only have one picture of it but I can't get it to upload.
I think they really suit it.
Post #442311 1st Aug 2015 9:45pm
Page 2 of 2 <12
