![]() | Home > Puma (Tdci) > Wabco ABS ECU not communicating with Nanocom |
The only thing you've disturbed since the last time it did communicate was the fuse under the steering column. I would get a voltmeter and start there. Perhaps a disconnection of the battery for a few minutes then a subsequent reconnect may 'soft boot' everything back into life, I am not sure but maybe worth a go?
You can also carry out a few voltage and continuity checks under the seat where the modulator and relay is to check you have the correct sensor values and voltage supplies. Do you have the diagrams? If not here's the link to them.....Good luck. https://onedrive.live.com/view.aspx?cid=4B...&wdo=1 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
robharvey Member Since: 14 Dec 2009 Location: Durban Posts: 86 ![]() ![]() ![]() |
Thanks for the tips. The only one I was capable of doing was the "soft reset" which, unfortunately, didn't work.
Problem solved. When I replaced the fuse I put it into the wrong slot. Feeling a touch embarrassed
