- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Tdi > Chassis-Bulkhead Bolts |
cornish rattler
Hi guys
I noticed today that one of my chassis to bulkhead bolts looked loose checked to see if it was tight and it was but there was a gap between the washer and bulkhead bracket, then i remembered from my series days that there are two bolt length's one for if rock slider's are fitted and a shorter std bolt for without any rock slider's fitted, my 90 used to have rock slider's fitted but was remove before i bought it, there is a build up of rust between the nut and the bracket which suggests the bolt wasn't tightened up properly i also want to fit rock slider's soon and want to buy the right bolts.
so are there two bolt lengths or just a std bolt that allows you to fit rock slider's Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
27th Jun 2015 6:03pm |
Harry.O
I don't have an LR part number but used M12 x 180mm bolts and they were fine with the rocksliders. A quick look on Google and this appears to be the standard size.
When I came to fit the fuel tank guard also, I had to go to M12 x 200mm on the driver's side because of the extra bracket.
Don't forget to cover them in copperslip
29th Jun 2015 5:41pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
