Home > Technical > RHS and LHS Capping Screw Part Number |
IainT Member Since: 17 Apr 2015 Location: Kinross-shire Posts: 9 |
Hi,
I replaced the RHS and LHS cappings on my 90 yesterday. The front and rear of each capping has a screw for attaching the hardtop. A couple need replaced. The one in the picture is OK. Does anyone have a part number or know where I can get replacements? I've checked various parts catalogues from over the years but can't see this. Cheers Click image to enlargeIMG_20150628_123028651_HDR by iain-t, on Flickr |
28th Jun 2015 11:48am |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Is this what you are looking for ?
http://www.lrseries.com/shop/product/listi...-STUD.html Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
28th Jun 2015 11:52am |
That's the one! Thanks a lot Bob
28th Jun 2015 11:59am |
Hi Martin,
A few tips that might help. If you don't have a workshop or garage to do it in wait until you have a day of good weather. I started at 9am and finished by 3pm. I would have been quicker except that I had a lot of extra drilling to do (see below) Buy some proper closed rivets. I bought these. I would buy 100 to be on the safe side: http://www.ebay.co.uk/itm/Land-rover-defen...4d339832f6 Buy a lazy tong rivet tool if you don't have one already. My hands would have been cramped with a normal hand tool: http://www.amazon.co.uk/Lazy-Rivet-Riveter...B00A38YDDY Have a decent metal drill bit and drill. I used a 5mm bit to drill out the existing rivets and holes for the new ones. I used genuine land rover cappings, but only about 6 of the rivet holes matched my existing (from factory) cappings. I had to spend a while drilling new holes and filling the old holes. This took most of the time. I put some waxoyl mix paint under the new cappings to try and keep future corrosion at bay. You don't always have to remove the roof, or use the windscreen hinges. I got away with detaching the hard top from the cappings, taking off the back door and removing the front and back door seals. i then used a jack in the bed of the tub and a wooden post with a T piece on the roof then raised the roof to give me enough clearance to do the job. Other than that just do a bit of googling. There's some great how to's already out there. I read through them and got lots of tips. Hope this helps. |
28th Jun 2015 3:50pm |
