![]() | Home > Technical > trucklite wiring |
wildcamper Member Since: 25 May 2014 Location: Lockerbie Posts: 112 ![]() ![]() ![]() |
Hi, ive fitted trucklite phase7 headlights today , went out to try them tonight and the dip beam and side light are working together in the side light position
Are they not just 'plug and play?'
**EDIT**According to this they are! http://www.mudstuff.co.uk/trucklite-phase-7-led-headlamps.html "For all Defenders fitted with the standard headlamp/sidelight set-up we can supply a piggy-back harness to provide the supply feed to the integral sidelight within the Truck-Lite LED Headlamp. The side light harness is fitted with Econoseal connectors that plug directly into the the Defender sidelight wiring (93-On). The flyleads connect to the corresponding wires on the back of the headlamps to create a simple plug & play connection to feed the integral sidelight within the Truck-Lite LED headlamp." Your issue is most likely down to the connections you made on the lamp itself as you state! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
You might need to unplug the dim dip resistor (rh wheelarch near the aerial)
Steve 02' 110 TD5 Double Cab Rebuild Thread |
yep sounds like dim dip still connected
Thanks guys dim dip is the prob, everything woks as it should without the engine running ,yet again forum to the rescue
