[For Sale] 2002 Td5 90 van Light 4x4 Utility
15p TD5
134k miles. Kkkk's spent. Full brake/axle/chassis etc overhaul last year..
Will come with new M.O.T
Tuned by B.A.S. inc. Allisport Intercooler, Boost box and custom re-map
Lots of upgrades inc. Mantec snorkel, rock-sliders, heavy duty drive members, heavy duty steering bars, Ali sump guard, Terrafirma rear diff guard, EBC disks and pads, BF braided brake hoses, Silicon engine hoses, Full upgraded Stainless Exhaust System de-cat + de-centre box. EGR valve removed.
Most of the work carried out last year and due to having company van hasn't been used much, apart from a flawless drive to Chamonix and back!
Chassis completely cleaned, red oxide primer, painted chassis black the wax-oiled inside and out.
1yr age all wheel Bearings replaced using adjustable 300tdi nuts, Front Swivel housing, front C.V joints, All stub axles and seals, Genuine Brake backing plates F+R, Gaz steering damper, Injector Harness, All mud flaps and brackets, Many parts blasted and powder coated inc. front bumper, front plastic outriggers shields, Evo 1 gearbox oil (cost £69!), Fuel filter and housing, diff magnetic drain bungs, Callipers overhauled with stainless steel pistons and new seals. Starter bendix contacts replaced, fuel regulator. etc 1500miles ago engine oil and filter replaced, diff oils and transfer box oil.
10k miles ago engine rebuilt with replacement cylinder head and £430 worth of rebuild parts from Turner engineering..
Loads of photos/receipts.
Wheels and tyres were replaced last year, full set came of a 2013/14 defender so still in very good condition.
Well looked after with no expense spared, Excellent runner, and very fun to drive.
Spare wheel + bracket inc. Ply-lined/shelved/security bulkhead,rear door and lock.
Mk1 nanocom diagnostic device, Mantec roof racks, stainless steel door hinges and an extra boost wheel + tyre also for sale.
£8750 o.n.o
Donations will be made if the above sells.
Contact Ross : 07718737264
g][/img]
14th Jun 2015 9:54am
Razler
Price reduced, £8000 for quick sale!! Call: 07718737264
21st Jun 2015 4:01pm
Razler
£7000 quicker sale !
24th Jun 2015 4:32pm
1963bus
Looks awesome, really clean
27th Jun 2015 10:14am
Bish
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
