![]() | Home > Technical > Breather pipe |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
There's a breather pipe in the NS rear wheel arch in my Td5 90, I assume it's connected to the fuel tank.
![]() Click image to enlarge ![]() Click image to enlarge Now that I'm able to see it properly, (it was previously entirely encrusted with mud,) I noticed that there are some splits in the rubber pipe where it bends. I'm concerned about dirt and water getting it through the cracks so I'd like to replace it but I can't see where the other end is. Does anyone know if it's a "tank-off" job to replace it or if it can be done it-situ, or for that matter if it's something completely different? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17705 ![]() ![]() ![]() |
When you repair/replace it, it is well worth running the pipe to somewhere more sensible (I ran mine into the rear body by the back of the rear light units).
It is guaranteed that with the breather in the standard position you will eventually find the tank becomes infected with the "diesel bug" due to the moisture and crud to which the breather is subjected. |
Thanks Munch, nice to know I don't have to run the tank out first
![]() Is the breather connection to the tank in the centre or is it off to one side? just trying to figure out the best way to get at it. Thanks also to Blackwolf, good point about re-locating it, makes sense ![]() |
you can normally see it though the gap between chassis and floor
instead of moving mine I fitted a inline fuel filter to the end then extended pipe off filter a bit to help stop any crap going up pipe not had a problem in 5 yrs since I done it filter like this eBay item number:261869145191 |
Slightly
![]() I recently had leakage from mine due to it splitting at the fuel filler end. I carried out an inline repair for the time being but will replace the entire length with reinforced pipe if/when it leaks at the tank end. Damn sight cheaper sourcing your own 'woven' reinforced 3/4" ID pipe than spending �70 on an OEM (Puma) one! ![]() Click image to enlarge ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Well that was a PITA fiddly job, got it done it though
![]() Looking through the gap between chassis and tub floor, (about 20mm,) I could see the rest of the pipe which had split and completely fallen apart near where it connects to the tank, I used a long small flat blade screwdriver to release the clip and a long pair of forceps to grab the remains of the pipe and pull it off, (long nosed pliers wouldn't reach.) ![]() Click image to enlarge ![]() Click image to enlarge I found a spare 2ft length of new 6mm fuel pipe in the garage, but there was no way it would go on the connector without being able to reach in there, so I had a look round and found a short length, about a foot, of �" copper pipe, the rubber flexi pipe was a nice snug fit inside it so after a bit of stretching with the tips of my long nose pliers and a smear of Fairy liquid, I managed to shove the end of the fuel pipe onto the connector using the copper pipe as a "handle", I then pulled the copper pipe off and routed the rubber one properly - job done. The thing that concerned me was the amount of mud on top of the tank and inside the old split pipe, I just wonder how much of that made it's way into the tank. Time for a new fuel filter perhaps ![]() |
I did warn you it was easy !
But thats exactly how i done mine with something up the middle of pipe to guide on mine was a bit of a proper pig to get on as i used braided high pressure pipe fuel pipe , as i couldnt be bothered to go out and get a bit of softer pipe and had a length of the other pipe in stock |
SteveD Member Since: 16 Oct 2014 Location: Suffolk Posts: 3 ![]() ![]() |
My breather pipe was in 4 peices and the larger one to the filler cap was split at the tank, so I did drop the tank out. Also allowed me to clean and paint the chassis at the rear. Nice to be able to fill the tank up now rather than the half a tank which would leak out if driving up hill!
Steve |
