![]() | Home > Maintenance & Modifications > Dinitrol over waxoyl |
I had my Defender professionally waxoyled several years ago. I now use Dintrol extensively as a top up and when fitting new items.
![]() Purchased from here: http://www.rejel.com/rejel-store/rust-proofing.aspx If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
df1 Member Since: 06 Aug 2011 Location: Ireland Posts: 221 ![]() |
I originally wayoyled my chassis and retreated the entire inside and out with the dinitrol products, very happy with results.
Anywhere surface rust appears, say where a chip etc is, I first touch up with a rust primer.
yorkshirelandy Member Since: 26 May 2015 Location: East Yorkshire Posts: 53 ![]() ![]() ![]() |
Cool, cheers guys. Think I'll order some from rejel.
Tom[/url] |
Why not re-use waxoyl ?
then you know it will go over alright if your defender is the one in the little pic and its 2004 it done 11yrs with waxoyl on |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5025 ![]() ![]() |
Treatments have moved on leaps and bounds since Waxoyl came on the market decades ago. It comes out lastsin tests as it doesn,t creep very well compared to others, it dries out leaving a cakey substance in very little time, it is a simple mix of wax, oil and white spirits and needs applying in a warm state, on vertical surfaces it has tendency to just slide down the side leaving a trace of white spirit and a heap of wax at the bottom, it is also not vibration proof, this is all well known and been said before on many forums etc... Better than nothing though and saved my old SAAB around flat, non abrasive areas back in the seventies.
The newer treatments such as Dinitrol, Bilt Hamber etc are solvent based so it like spraying on a waxy, oily glue and coats/seals waxoyl very well. They also last longer. Clients cars I did 4 years ago are still good ![]() |
got cars here waxoyled once 16 yrs ago and still good
my old defender pick up 87 d reg still good never needed any welding etc ( sold in 93 ) that's 28 yrs with waxoyl my 93 k reg 90 ht was as new when I sold in 07 it done once with waxoyl when new |
waxoyl has definitely stood the test of time!!
I think i may just top it up this summer but do an internal dinitrol job. |
Main thing is how good the surface is to start with , how many bits you want or need to remove to get proper protection , how good your equipment is , and of course knowledge of the bits that need best protection like impact areas , water/mud traps etc
Hi Zag, As you now appear to the Def2 resident rustproofing expert perhaps you can cast some light as to the difference in the solvent used in the two named products given the above. In my own humble experience both Waxoyl and Dinitrol will thin with white spirit. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
