Home > In Car Electronics > Defender Trailer Electric Socket Problem |
The trailer socket is quite common for corroding on the inside so you might be best unplugging the whole wiring section under the drivers side rear arch and Unbolting the tow socket, dismantling and checking all the wires. Ray
25th Jun 2015 12:16pm |
peter21 Member Since: 25 Jun 2015 Location: Cumbria Posts: 2 |
Thanks Ray. I did unbolt the socket to get at the back. The connections have been set in a solid lump of some sort of silicon sealer and did look sound.
Peter |
25th Jun 2015 12:42pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20480 |
Add a jury earth ( temp earth) then see what happens, most likely cause in my opinion.
Check earth stud / strap on transfer bid if a Puma, clean and refit. |
25th Jun 2015 1:54pm |
