Home > Technical > RAL code Fuji White
Penguin
Belgium 2015 Defender 110 Puma 2.2 HT Chawton White
RAL code Fuji White
Hi all,
How can I find the RAL code of out def 2015 fuji white?
thx 28/02 - Loss of a good friend...
In a time of chimpanzees, I was a penguin.
Post #433482 25th Jun 2015 6:00am
K9F
Take your truck to any decent body shop and they should be able to test and give you the RAL code perhaps? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #433501 25th Jun 2015 8:30am
Penguin
I guess that will be the only option. Google isn't helping 28/02 - Loss of a good friend...
Post #433503 25th Jun 2015 8:33am
K9F
That's the route I think I would take to make sure I got an exact match. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #433505 25th Jun 2015 8:35am
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
We use RAl colours a lot in the furniture industry to ensure matches of finish between manufacturers, had a look at the RAL charts and there are a handful of whites to choose from, however as Fuji white is mixed to Land Rover's specification rather than to a RAL standard it will be almost impossible to find an exact match, as K9F says the best thing is to have paint mixed to match the code on the vin plate 👍👍
http://www.ralcolor.com 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #433508 25th Jun 2015 8:45am
leeds
Fuji White has Land Rover colour code 867 which paint shops should be able to match up.
Brendan
Post #433526 25th Jun 2015 9:35am
Retroanaconda
Google works fine:
https://www.google.co.uk/search?q=RAL+code...gws_rd=ssl
Fifth result down gives you a code of 867.
Post #433559 25th Jun 2015 11:37am
gumdrop
RAL is a colour matching system used in Europe. In colloquial speech RAL refers to the RAL Classic system, mainly used for varnish and powder coating but nowadays there are reference panels for plastics as well. Vehicle manufactures very rarely use RAL colours and usually creat their own which are given a unique reference.
See https://en.wikipedia.org/wiki/RAL_colour_standard for further info on the RAL colour standard. T
he UK has a seperate standard BS 381C, BS4800 and BS5252 - see http://www.e-paint.co.uk/BS381%20Colourchart.asp
Then there is the NCS system ...... (Dulux mixed paint is based on this)
This site - http://coachpainting.info/index.html - is great as it gives most Land Rover used the first column being the paint ref - body shops work to this or the last column is the LR code (used when ordering a touch up kit fro a dealer etc)
Mine being a 50th is Atlantis Blue ........
Code Name Year Land Rover Code
JYW Atlantis Blue Mic 2ct 98-98 LRC.632
Hope this helps! Cheers
Simon
50th D90 - my toy!
Freelander SE Td4 3 door - local run around
1958 Series 1- Rag top!
Post #433688 25th Jun 2015 10:32pm
