![]() | Home > Td5 > Variable intermittent wipers for TD5 Defender |
pos a faulty relay,it shouldn't effect the washer action 2.4 90 XS
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Ive fitted two of these into my 300tdi.
The first one caused my wipers to remain on permenantly, until the relay was pulled out again. The second one almost worked, but the wipers only did a quarter of a wipe at a time, causing them to stop halfway across the windscreen. My quest for variable intermitent wipers continues... |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
I have one in my TD5 and it works perfectly. Think you may have a faulty relay.
Pete. |
![]() 1968 1/32 scale Britains 109 Pick up. |
Lionel Member Since: 12 Aug 2008 Location: Melbourne Posts: 59 ![]() ![]() |
Yep! Exchanged the relay for another one & all OK. Thanks for information.
Cheers, Lionel |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1879 ![]() ![]() |
I'm with Zinke - all good. Just done the intermittent rear wiper mod and also happy - though more work than expected!
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17640 ![]() ![]() ![]() |
Interesting fault. In the recent really cold weather I have found that if I use the intermittent setting on the wipers they will not stop, just wipe continuously even iff switched to the off position. The only waty to stop them is either to switch off the 'ignition', or, as I found this morning, to blip the windscreen washer after which they will park normally.
Once the cab has warmed up a bit, it all works fine again! The relay was second-hand, so its history is unknown. Despite this, I still think this is one of the best low-cost upgrades. |
