Home > Puma (Tdci) > Slight over rev when changing gear & in Low range |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 |
In low first the revs rise to about 1000 and stay there, even trying to slow it a bit on the brakes don't work, it just keeps on going. I must admit it does make super-slow manouvering quite hard work.
22nd Oct 2010 10:49pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 |
Its called the Idle Jack.
Search +idle +jack http://www.defender2.net/forum/topic1177.html?highlight=idle+jack http://www.defender2.net/forum/topic423.html?highlight=idle+jack 130's have feeling's as well you know |
23rd Oct 2010 7:24am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8155 |
idle jack, to overcome the low speed in 1st low which LR deemed was too slow. takes it upto 1100rpm. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
25th Oct 2010 1:05pm |
gtveloce65 Member Since: 10 Nov 2008 Location: West Sussex Posts: 107 |
In addition to anti stall and throttle ramp in low-range, mine (2008) had the same issue in high-range. I understand this was achieved using a switch on the clutch to increase revs between gears to reduce transmission shunt - it didn't really work too well and made it sound like I couldn't drive properly
Successive clutch upgrades and maybe newer engine management patches over the last 2 years, and it doesn't do it any more - I wondered what year is your Defender? 1953 80 1965 Alfa Romeo GT Veloce Sprint 1980 Fiat 124 Spider 2008 110xs |
2nd Nov 2010 4:30pm |
Homra Member Since: 22 Oct 2010 Location: Hillsborough Posts: 2 |
mine does the same in high range, like you say as if you don't take your foot off the acelator to change gear, mine is 2010 |
10th Nov 2010 9:15pm |
