Home > Maintenance & Modifications > removing the stearing wheel |
67_6Cyl Member Since: 10 Feb 2010 Location: France Posts: 97 |
I'm after a magic tip / trick.
I am trying to remove the steering wheel to replace the indicator / dim / dip / horn switch. It looks like the steering wheel has been fixed onto the splined steering column with threadlock, or at least wanged on far too tight. I have made a puller bar that screws into the two M6 threads either side of the boss, and pushes on the splined inner column. All that this did was manage to bend a piece of 1/4 inch thick steel, and not remove the wheel from the splines. - I have also soaked it in WD40 and PlusGas, without any effect. Help. Any ideas as to how to remove the wheel from the column? Thanks Jon |
24th Jun 2015 11:13am |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5108 |
Probably not a great help but I mention this just in case you are having the same problem as I once had.
I had the same difficulty with a steering wheel and no matter what I did I could not remove it. Turned out some nutter had hammered a 36 spline wheel onto a 48 spline shaft to get it to fit. Ended up having to cut the wheel off and replace the column. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
24th Jun 2015 11:27am |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello 67_6Cyl
I had a similar problem, mine had a Startech Steering wheel fitted which was 1 spline out in alignment... and was also really tightly engaged onto the splines. I used a Puller to apply an even force to the Boss...which is the key here (I would suggest)... You think it's not going to move and then it releases, just take your time and check for true alignment as you go... As you can see I took the Steering wheel off the Boss in order to do this Good Luck Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
24th Jun 2015 11:33am |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
Nothing wrong with an accurate and proportional blow with a hammer if all of the above fail (using the puller in combination) 2002 90 Td5 Station Wagon
24th Jun 2015 11:48am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17322 |
Use a bigger/stronger puller.
You don't actually need to get the wheel off to do what you need, it is possible to remove the switch from the mounting plate and swap it over. You have to be careful as there are springs and small parts which can fall out, but it is possible - I have done it in the past on my 2.4. |
24th Jun 2015 12:18pm |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
Have you tried holding it at 12 and 6 then 3 and 9 rocking back and forward frequently dont try to pull but rock it as this may loosen it...then pull! |
24th Jun 2015 5:37pm |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 574 |
All good advice.
The only thing I would add is,leave the center nut on a few threads,then if it comes free whilst your pulling / banging it,it wont smack you in the face. Bonne chance. Marc Last edited by sharkey964 on 24th Jun 2015 6:54pm. Edited 1 time in total |
24th Jun 2015 6:53pm |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1217 |
!!!!! Remember to leave the nut on the top of the thread when pulling/banging!!!
How many of us have had a steering wheel in the face?!? EDIT...30 seconds too late ^^^^^^^^^^^^^^^^^^ Clemmo Make today a little better than yesterday but not so good as tomorrow.... Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadster……..........Vermillion 17k miles Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun |
24th Jun 2015 6:54pm |
cheers guys.
I have tried the rocking and hammering, but without success - but I did keep the nut on, just in case. I have now ordered a proper steering wheel puller. Best Jon |
25th Jun 2015 10:06am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6603 |
Ensure the puller you use puts pressure on the column, not on the 2 M6 threads. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
25th Jun 2015 11:05am |
Quick warning, it turned out that the threads in the central boss to pull from were 1/4 UNF not M6........
Built in 2007..... And still a mix of UNF and metric....... Jon |
12th Jul 2015 4:42pm |
ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221 |
I've also made my own puller. 18mm A/F hex bar, 6mm bolts as per and an m12 bolt through the centre. Works every time, and you won't bend it. It wasn't me! |
15th Jul 2015 5:43pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Completely slacken the nut. Lock the tab to stop it coming undone anymore.
Then drive it 'til it comes loose. Won't take long. (Especially on potholed roads ) |
15th Jul 2015 5:49pm |
