Home > Td5 > Pimp my ride, so to speak |
dougelec Member Since: 18 Apr 2014 Location: Sunderland Posts: 31 |
Bought my Td5 110 defender just over a year ago as weekend, greenlaning type car but since then I've completely fell in love with the experience, sold my relatively new Kia and now the Landy is my daily drive. It's in good nick for fifteen years old, the engine is spot on and the whole family love it, especially our Border Collie, who would galdly live in there if she could.
My only gripe is how tiring it is to drive on long runs. We regularly drive over to the Lakes, which is approximately a two hour run, and I'm knackered by the end. I've fitted a Noise Killer sound insulation kit in the front, a blanket over the engine and am currently lining the load space and wheel aches with Silent Coat, which will hopefully make a difference. I have funds from the sale of the other car so I was just wondering if anyone could suggest other ways to make the Landy a more comfortable drive and what they'd add if money were no object. |
22nd Jun 2015 10:02am |
bluebottle Member Since: 08 May 2015 Location: Not in my Landy enough! Posts: 705 |
I'm in a similar position.
I'm looking towards an ECU remap and exchange of the high-ratio box for a Discovery one to enable lower engine revs at motorway speeds. These are not cheap though so I'm probably going to do that sometime next year when I've saved up. However, I am seriously considering new seats - I'm eagerly awaiting developments on this thread actually. |
22nd Jun 2015 10:41am |
New seats, sounds obvious but never entered my head. We're off to a good start!!!
22nd Jun 2015 10:46am |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
As Bluebottle says, swapping to a Discovery transfer box is a good way to bring the revs down at motorway speeds, alternatively an overdrive unit is another way to achieve the same rev reduction while still maintaining the lower gear ranges for lower speed manoeuvring, towing or off-road etc.
Mine came with a GKN overdrive already fitted ( ) and it makes a huge difference to the engine noise when engaged at 60 or 70 mph. |
22nd Jun 2015 10:50am |
Yeah, that was the other thing - for night driving - new lights... I've put Wipac Crystals with Osram Nightbreakers on mine... Typically did it at the height of British daylight so I'll have to either get up in the middle of the night or wait a few months to find out how much of an improvement they've made!
One other thing - just prompted by the cabin photo above - maybe get the handbrake moved as well? I've heard of mods using an old Range Rover unit mounted on the transmission tunnel... Probably easiest to do this when changing to Disco cogs as all that stuff has to come out anyway I imagine. Don't forget to keep us posted on any mods - we all like piccies of new shiny things! Have you got a thread in My Defender? |
22nd Jun 2015 11:22am |
Thanks so much for all of the suggestions.
Think the lights and steering wheel have already been replaced, so they're no longer an issue. Bought the Silent Coat primarily for the roof but I'm a little apprehensive about removing the lining - suppose I'll just have to go for it. Does the entire surface of each panel need covering, will leaving a gap make much of a difference, and have covered from the wheel aches to the windows and doors? Can anyone tell me where to get the foam insulation from? Changing the seats sounds like a plan, although I should imagine fitting nonstandard units require quite a bit of work, and I'll definitely look into the gearbox/overdrive option. What should I be looking for to fit a 2000 Td5? Thanks again and keep the suggestions coming, please. |
22nd Jun 2015 12:02pm |
Bluebottle, I haven't got section in my defender buy I'll certainly look into it.
I'm writing this from the back of the Landy while the rain lashes down, is there any better noise?? |
22nd Jun 2015 12:06pm |
Slipped my mind about the handbrake mod, it feels so natural that I don't think about it, easy mod to do
Mine's a Disco 2 lever mounted through the top of the seatbox with the original cable hooked up and the original mounting hole blanked off. Click image to enlarge |
22nd Jun 2015 12:14pm |
Did you move the handbrake yourself?
22nd Jun 2015 12:18pm |
Yes I did, it probably took longer to measure up make up the reinforcing plate to go under the seatbox than to actually fit it.
22nd Jun 2015 12:29pm |
I'd respectfully suggest that you keep your money in your pocket for a while longer. As an analogy if you are a 1500m runner and then just swap to running a marathon it will feel different. Changing your running shoes will not stop you being knackered at the end of it. Yes there will be some environmental changes that will help - but not more than a change of mindset. You need to settle back and enjoy the different experience until it becomes the norm for you - train your body. If two hours completely knackers you, why not stop after an hour and stretch your legs. Leave 10 minutes earlier and maybe arrive 10 minutes later but feel better for it. Two solid hours in my Defender is something I'd look forward to rather than treat as an obstacle. The above may be a fairly masochistic viewpoint but it's why I bought the vehicle in the first place - it's a far more basic driving experience and therefore requires more of an involvement from you; the consequence of this is that until you are used to it, it will tire you out more than you think at the start. Just be grateful it has a roof, doors, windscreen and a heater - all compromises for a real driving experience |
22nd Jun 2015 1:55pm |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
^^^ tend to agree.
I find the standard seat pretty good in my TD5 (and I've got a D4 and Evoque to compare them to), but I'm only 5' 10" so perhaps if your taller it makes it worse. It might be worth checking if the seats are just tired, the foam isn't the best. A smaller steering wheel helps if you find you are hitting your elbow on the door. Noise wise I used to run Grizzly Claw tyres and it sounded like a RR Merlin engine at take off..! Now I have BFG KM2 MT and they are as quiet as a mouse. The main noise that is distracting for me are the stones bouncing off the rear wheel arches, but I just carry more gear in the back to hide that noise. (....or perhaps I'm just getting deaf in my old age..) cheers simon |
22nd Jun 2015 2:05pm |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 |
Just a note, the overdrive, (namely the RoamerDrive - not sure on the GKN) drops the gearing lower than the 1.2 Disco box. It's not the same as mentioned above. Drops the RPM even further than what the Disco drive gear will do.
If they weren't £1500, I think they'd sell them by the bucket load! |
22nd Jun 2015 3:30pm |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 |
Interesting topic...is there any particular modification required to fit new seats or do they just slot in so to speak?
Those Mazda seats look good |
23rd Jun 2015 5:58am |
