Home > Td5 > Wonders will never cease
cobra_mark
United Kingdom 2000 Defender 90 300 Tdi SW Barolo Black
Finally got round to checking the oil levels of the transfer box and gearbox of my Defender 90 and was pleasantly surprised to see they were good and clear from the slight drip over the lip of the fillers.
I did the front and rear axles a month ago and was not impressed with the front axle being black and very old.
Both now new oil and golden clear.
Razz
Post #432435 20th Jun 2015 7:58pm
munch90
Grease from outer hubs has more likely got in to axle oil turning it black and old looking
it will be the same as before soon
Post #432436 20th Jun 2015 8:00pm
cobra_mark
A change of inner seals maybe then?
Post #432439 20th Jun 2015 8:07pm
cobra_mark - you can put your vehicle details in your profile so we know what you have/how old it is?
Was surprised to see the difference in the colour of the oil between my diffs. The front was black whilst the rear was still golden. I was wondering whether i could put this down to the front diff doing more work than the rear or whether I should be looking for an issue. Oil level was certainly not higher in the front.
Post #432534 21st Jun 2015 10:16am
munch90
it will be the cv grease from the front hubs
a spoon full of cv grease will turn oil black and not enough to rise oil level that you would notice
Post #432535 21st Jun 2015 10:21am
Rather hoping it wasn't as not expecting that on an axle that has done under 10k miles!
Is there another way to confirm diagnosis easily?
Post #432542 21st Jun 2015 10:48am
cobra_mark
Having a big garage session to sort out brakes, shocks etc. so will look at the seals.
As to my profile it appears to be filled in correctly so not sure why the details are not visible ?
Post #432612 21st Jun 2015 6:33pm
Have you looked at the "My Defender Profile" section Thumbs Up
Post #432614 21st Jun 2015 6:37pm
cobra_mark
Yes all there, do you want me to get Martin to check it out?
A bit confused.
Post #432623 21st Jun 2015 7:15pm
Well it's there now! Thumbs Up
Post #432783 22nd Jun 2015 11:12am
cobra_mark
Great, just typed it out again and saved it must not have registered. Smile
Post #432790 22nd Jun 2015 11:24am
