Home > My Defender > The Gun bus.
Page 3 of 4 <1234>
Gunbus
Scotland 2015 Defender 110 Puma 2.2 USW Corris Grey
need4speed - Thank you for the compliment. Good guess on the rifle but its a 30-06 cal Thumbs Up
Post #431851 18th Jun 2015 8:34am
need4speed
Jeez that's a weedy looking 30 aught 6 Laughing
Just kidding. Probably just the angle. Where do you shoot? I've shot up Garelochhead a few times.. Thumbs Up
Post #431855 18th Jun 2015 8:43am
Gunbus
Good guessing guys - Machine gun parts would have been fun! Although you were right with the spacers.
I went for the Terrafirma 30mm set. It gives the vehicle a slightly different road presence. I found it slightly more stable at high road speeds. However the main reason for fitting was not anesthetics, it was for turning circle improvement. I adjusted the steering stops and checked clearance. Opted not to go too far with the stops to give plenty clearance for mud against the radius arms. Used a little silver grease to prevent alloy welding to steel!
Great success - it now turns like a London cab! (not really but an incredible difference to standard)
And before anyone tells me - yes I know the sides will get even more caked with mud but its a defender...Rolling with laughter
Will try get some better after pics for comparison.
Post #431862 18th Jun 2015 9:00am
dave w l
England 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Hi gunbus have U managed to get a gun rack in the back behind the front seats. I'm just looking at making my own as there doesn't seem to b a manufactured one .The trouble is mines a 90 with rear front facing seats so there's not a lot of room.? Anyway nice landy . Use it and love it and stay safe.
Post #431868 18th Jun 2015 9:18am
need4speed
Try Brattonsound. I thought they did some nice ones Question
Don't you mean cabinet Question
Post #431870 18th Jun 2015 9:20am
dave w l
Hi gunbus thanks for that I will contact brattonsound asap I have one of there safes. Thanks .dave
Post #431890 18th Jun 2015 11:11am
Gunbus
Dave - No gun rack yet, I'll come up with something one day.
Need4speed - The pic makes it look small. I have just got a new Blaser R8 and its even more compact!
Post #432144 19th Jun 2015 10:59am
Gunbus
Another box has just arrived - Can you tell what it is yet??
Post #432147 19th Jun 2015 11:00am
dave w l
Hi gunbus no not yet brattonsound don't do them. There's just not enough height for a vertical rack so I will just keep it in the motoring case. Stay safe.
Post #432151 19th Jun 2015 11:25am
shaggydog
Ohh 2" Lift kit perhaps? Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #432161 19th Jun 2015 11:58am
Gunbus
shaggydog - - in the words of Roy Walker "you're right!"
Post #432197 19th Jun 2015 3:15pm
shaggydog
Very Happy
Out of interest, why did you go for the spring spacer rather than longer springs?
I went for longer springs on mine and have since taken them off but at the time it was 50/50 between the two.
Truck is looking great by the way Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #432274 19th Jun 2015 9:49pm
Gunbus
Thanks Shaggydog,
I didn't do too much revision to be honest. Looking at the spacers I had it in my head that I would be able to retain the same shock travel. Although this works for the front it wont for the rear.
Anyway I am still in the process of fitting. The rears I cant go wrong but the fronts I want to double check. The front spacers have a hole on one side big enough for the sock to go through, but when I fitted it this way up the shock ain't long enough to fit the lock nut etc.. When I fit the spacer the other way round it makes more sense although tightening the lock nut is tricky due to the lack of accessibility. I'm not 100% sure what the reason is for the large hole on one side of the front spacer?
As you can tell I'm no mechanic, I will seek professional advice to make sure I am happy before I proceed!
Did you have to change the shocks along with the longer springs?
Post #432730 22nd Jun 2015 7:33am
Gunbus wrote:
Are the wheel nuts just finger tight there or is that as far as they go down the threads?
Post #432797 22nd Jun 2015 11:36am
Gunbus
Finger tight my friend.
I then screwed then up with the impact gun, checked torque setting with torque wrench (torque setting TAF)
Post #432803 22nd Jun 2015 11:55am
Page 3 of 4 <1234>
