Home > Technical > Revs stay high
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
Revs stay high
SOMETIMES my MY2008 Puma's revs stay high when I change gears (take foot off accelerator) for a second or two, before dropping down.
What's causing this?
Thanks, www.ralton.co.za
Post #432070 19th Jun 2015 6:04am
dgardel
Italy
Check the clutch switch installed on the clutch pump (engine bay)
It is a pressure switch and, easily, IT IS the problem.
If you want test, short circuit the connector with a piece of electric wire (harness side, not the switch) and test the car. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #432080 19th Jun 2015 7:44am
ralton
I'm not sure what the "clutch switch" is? - are you referring to the "clutch pedal sensor"?
Thanks! www.ralton.co.za
Post #432082 19th Jun 2015 7:58am
dgardel
Italy
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #432095 19th Jun 2015 9:03am
Daft though it sounds, check that the brake light fuse hasn't blown and that there aren't any issues with the brake lights.
On a 2.4, the brake light circuit is an input to the ECM and rev hang is one symptom of a brake light malfunction.
Post #432131 19th Jun 2015 11:30am
dgardel
Italy
Re: Revs stay high
Thanks,
IMHO is the switch.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #432150 19th Jun 2015 12:20pm
