![]() | Home > For Sale & Wanted > [SOLD] Pair of Rigid industries dually spectre spots |
Brand new, Comes with loom, switch and relay, White spot pattern, would be ideal to fit behind grill or in/on bumper
Bought for a project but not used - still boxed/ bagged but opened Specification here: http://www.zenoverland.com/led_lights/rigi...ights.html This is for a pair - asking £150 Ono inc UK mainland postage DESCRIPTION: Big Power in a Small Package - The Rigid Industries D-Series LED Light is one of the most versatile lighting products on the market today. It produces extremely high output while consuming very little power. Its compact size and shape allow the D-Series LED Light to fit almost anywhere and be used for virtually any lighting application. Specter Optics - Our patented Specter optics system features 50% more LED's than our Hybrid optics in the same footprint and is specifically designed to cover more area. By incorporating a reflector with no facets or orange peel, the Specter optics system produces an intense, smooth beam with minimal wasted light. Hyperspot - 5 degree ultra-narrow concentrated Spot beam pattern for long distance applications. Patent pending aperture system blocks unused light for a clean beam. Highest intensity per watt or square inch on the market as well as Maximum Distance! Quality Construction - Our circuitry is designed in-house to be more powerful, be more efficient, and generate less heat. Our durable aluminum housings feature custom, over-sized heat sinks which keep the temperature down and allow our LED's to run cooler and brighter. All Rigid Industries LED lights receive a high quality powder coat finish, a custom-molded rubber seal, and an unbreakable, scratch resistant lens. Rigid Industries LED lights are engineered to withstand whatever you, the road, or nature can throw at them. Kit Includes: Plug and Play Harness with Switch as well as Mounting bracket and hardware. FEATURES: Patented Specter Optics Hyperspot Pattern 50,000+ Hr LED Lifespan Instant On / Off - No Warm Up RoHS Compliant Over / Under Voltage Protection Cast Aluminum Housing Durable Polycarbonate Lens Integrated Thermal Managament GORE® Pressure Equalizing Vent Designed, Engineered, & assembled in the USA Sealed Deutsch Connector SPECIFICATIONS: Watts: 20 Amp Draw: 1.45 LED's: 4 Raw Lumens: 1760 each Lux @ 10m: 810.0 Beam Distance: 569.2 m Peak Beam Intensity: 81,000 cd Last edited by bpman on 18th Jun 2015 5:29pm. Edited 1 time in total |
McS Member Since: 05 Oct 2009 Location: Banbury Posts: 686 ![]() ![]() |
Yes please
You have a PM
Borro Member Since: 22 Jul 2012 Location: Varese/Stockholm Posts: 41 ![]() ![]() ![]() |
Gone?
Yes
