Home > Puma (Tdci) > Limp mode / Ultragauge
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
I have the following situation today, just after starting the engine:
Tachometer dead
Temperature gauge goes immediately to maximum
Battery charging illuminated (other gauges show the battery charging normally)
Drove few miles, realising I am in limp mode. Quick look at Ultragauge - it was trying constantly to connect (scanning), while it should be on.
I have checked all the fuses and only after disconnecting Ultragauge the engine started normally. After re-connecting Ultragauge it scanned the port and started normally. Re-stared engine worked normally.
Is that possible for a ODBII scanner to send "wrong" signals that may cause such failure or shall I look for the reasons beyond Ultragauge? In few weeks I leave overland to China and back - knowing the cause will help me to keep peace of mind.
Cheers! Janusz
www.yahodeville.com
Post #431776 17th Jun 2015 8:59pm
Lorryman100
Post #431781 17th Jun 2015 9:13pm
LoveB
2013 Defender 110 Puma 2.2 SW Orkney Grey
Gotta let it load before you start it Very Happy
Post #431828 18th Jun 2015 6:34am
yaho
Seems to be not fully clipped connector to the instruments clusters.
Clipped and fixed.
Thanks for the hints Thumbs Up Janusz
www.yahodeville.com
Post #432876 22nd Jun 2015 6:25pm
