Home > Off Topic > 12v Electric Pump to fit into 20lt Jerry cans
LinDens90XS
2003 Defender 90 Td5 XS CSW Bonatti Grey
I have heard that some use a pump to transfer water from jerry cans on the roof or for a quick shower.
I am wondering if there is a pump that can be used to transfer diesel from a 20 Lt Jerry can as I find it quite awkward holding a full can now and it would be impossible for my wife if she were on her own and ran low on fuel.
Does such a thing exist? Any thoughts appreciated. Regards
Dennis.
Post #431182 15th Jun 2015 8:41pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi Dennis
Something like this electric pump I gut be what you're looking for Thumbs Up
https://www.machinemart.co.uk/shop/product...20transfer 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #431203 15th Jun 2015 9:24pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Where is the jerry can located?
If it's in the back you should be able to just stick a pipe in the jerry and another in the filler pipe and let gravity do the work, but you might need to suck on the exit end to get it flowing Thumbs Up
otherwise there are plenty of diesel pumps on ebay with an inlet pipe and outlet pipe, so you can fit a small pipe into the jerry can Thumbs Up
Post #431205 15th Jun 2015 9:26pm
munch90
Google facet fuel-it transfer pump
or
Polarn Jerry Can Fuel Pump
Post #431209 15th Jun 2015 9:34pm
DuncanS
United Kingdom 2008 Defender 110 Puma 2.4 USW Santorini Black
One of these does the trick for what we use.
http://www.whalepumps.com/rv/product.aspx?...tric-Pumps North Cumbria Search and Rescue - Team Leader
Post #431215 15th Jun 2015 9:51pm
Eduardo
I have my jerrycans in the roof rack and with a manual pump and the gravity is enough
Cheers Eduardo
Post #431231 15th Jun 2015 11:17pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Hi Dennis
Where about do you/your wife travel that is remote enough to warrant carrying extra fuel? You may be over thinking this as in all my travels around the UK the only time I have been close to worrying about running short of fuel is in mid-Wales on a Sunday when all the remote garages often shut from Sat afternoon until Mon (and that is in an old 90 with tiny side mount tank). If you are based in and travelling/working around Merseyside then I suggest you just plan a bit more carefully about keeping fuelled up as there really shouldn't be any need for the complications of carrying and transferring fuel in most parts of the UK.
I apologise if you are actually going on an expedition to some remote foreign land and I am giving the wrong advice Thumbs Up
Post #431256 16th Jun 2015 7:26am
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Post #431259 16th Jun 2015 7:47am
Laser Jiggle Siphon Hose 1.75m x 20mm - used something like this quite successfully previously:
http://www.screwfix.com/p/laser-jiggle-sip...20mm/23447
but have you considered the obvious - carry two 10 litre cans instead of a single twenty or have something to decant into on the floor that you can use by just tipping the 20 litre can whilst it's on the floor also?
Post #431273 16th Jun 2015 8:35am
Best solution we use is from Frost Auto Restore involves a 12v compressor works really well for fluid transfer
Post #431289 16th Jun 2015 10:34am
LinDens90XS
Thanks to everyone for all your suggestions, from the cheap to the expensive. because I have never needed anything like this, did not know so many options that could handle diesel, always thought those for water were not suitable. I like the idea of the electric ones but taking into account grounding and price, I think two 10Lt can will be the answer, as very manageable and safe. In reply to I Like Old Skool, it is mainly for our run down to Cornwall when I always seem to be pushing it on the last leg. Have never actually run out as I top up with the can, I suppose 20Lt is is a bit overkill.
Thanks again to everyone. Regards
Dennis.
Post #431619 17th Jun 2015 1:31pm
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
With both the 90 and the jimny the tank size is miniscule with both the range is in the order of 250 miles and the honest truth is that even with a near continuous trip round the remotest parts of northern Scotland I have never had recourse to my jerry can. Ok I have to stop for fuel in either car much more frequently than my old discovery but it's easy to plan long trips in legs with fuel stops even in the back of beyond. Rhubarb and custard let fly with their secret weapon.
Post #431653 17th Jun 2015 3:27pm
I Like Old Skool
This ^^^^^^
Don't make it harder than it needs to be Thumbs Up
Post #431668 17th Jun 2015 4:10pm
