Home > Technical > Alternator not charging : 2.25 S3
keith
Alternator not charging battery on 2.25 petrol military 12v lightweight , is it an external voltage regulator or standard Lucas unit that's just knackered ?
Post #429834 9th Jun 2015 8:55pm
martinfiattech
Is it something like a lucas Acr unit.
If so the regulator is internal to the unit.
Does your battery warning light come on with the ignition. (engine not running) Run engine for full testing. of alternator.
If it does and the battery charge output B+ from the back of the alternator is less than or the same as standing battery voltage.
Then yes the alternator is not charging.
If the battery light does not come on as described the field circuit is not being exitcited.
The alternator needs to see battery voltage on the field wire so it knows what to do.
This should be battery voltage (when disconnected from the alt)
Hope this helps.
Don`t forget the earth`s, belt tension, state of battery. And general connections.
All the best. Excuse the spelling I`am better with spanners and wires.
Post #430108 10th Jun 2015 9:08pm
keith
Thanks
Lucas 16ACR. The red charging light comes on when started and then goes out , looking as though it's charging but it's not .
All connections clean and earthed , belt ok , just no charge output from alternator . Reckon it's goosed .
Thanks for the info mate . Thumbs Up
Post #430113 10th Jun 2015 9:16pm
