Home > Maintenance & Modifications > Help with removing XS front set covers |
'Go Beyond' may be able to advise as he retrims seats. Drop him a 'pm' perhaps? If you go through life with your head in the sand....all people will see is an ar5e!!
7th Jun 2015 4:29pm |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 248 |
Do you mean the backrest? I tried to do mine about a year ago. The cover is fastened on with 'hog rings' i didn't actually take mine all the way off but there's a load of them going up the backrest. 1953 80"
1987 mini city e 2011 90" |
7th Jun 2015 5:41pm |
miket Member Since: 05 Oct 2012 Location: Peak District Posts: 143 |
Thanks Mr_James - must be the hog rings. Might see if I can snip them off without a special tool and might consider replacing them with cable ties...
A job for next weekend. Cheers Mike |
7th Jun 2015 6:06pm |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
Exmoor trim do quite a good "how to" video covering seat re-trim -
http://www.exmoortrim.co.uk/re-trim-a-defender-seat-pt-1.html |
7th Jun 2015 6:37pm |
Thanks Clive - I had seen this and the cover just pulls up and off, which mine certainly doesn't do. All down to hog ties...
7th Jun 2015 7:49pm |
