Home > Td5 > TD5 water pump - is it shot? |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
Yes looks like it
3rd Jun 2015 7:01pm |
Super7 Member Since: 05 Feb 2014 Location: South Bucks. Posts: 132 |
Thanks, that's my weekend sorted then '99 TD5 Defender 90
'52 Series 1 80" '99 Caterham 7 |
4th Jun 2015 8:02am |
Easy enough. Get the gaskets and 'O' ring for the centrifugal filter housing as it needs to come off.
4th Jun 2015 6:35pm |
grumpy old git Member Since: 16 Nov 2013 Location: United Kingdom Posts: 153 |
I've seen it done another way, remove PS pump from housing, four bolts to remove the entire bracket assembly from the lump and then swap the pump on the bench. There is an O ring that'll need swapping but it allows you to torque the pump bolts up correctly. I'll post the O ring part number when I get on the PC.
5th Jun 2015 8:03am |
I've seen it done another way, remove PS pump from housing, four bolts to remove the entire bracket assembly from the lump and then swap the pump on the bench. There is an O ring that'll need swapping but it allows you to torque the pump bolts up correctly. I'll post the O ring part number when I get on the PC. There's a post on d2boys club that is useful.
5th Jun 2015 8:04am |
Each to their own but I find that way an absolute pain in the backside. You'll do it easily in an hour or so by removing the centrifugal filter.
5th Jun 2015 6:01pm |
Thanks, all sorted, took the centrifugal filter housing off '99 TD5 Defender 90
7th Jun 2015 7:38am |
7th Jun 2015 11:27am |
