Home > Maintenance & Modifications > Replacing brake fluid. Any pitfalls with ABS? |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1314 |
I turned down the offer of replacing the brake fluid for £84 this week at my third year service as I though that sounded a lot of money for a simple job I could do myself.
I've bled the brakes on plenty of older vehicles before, but never one with ABS. Is it as straightforward as this post ? http://www.defender2.net/forum/topic4499.html?highlight=bleeding My plan is to : Draw out as much of the old fluid from the master cylinder reservoir as I can using a syringe without allowing any air to get into the cylinder ports. Top up the master cylinder with fresh fluid. Starting with the rear callipers first, do the old "down", "up" routine with my son on the brake pedal and me cracking open the calliper bleed nipples one at a time using my old faithful silicon brake bleeding tube attached to the nipple. Monitoring the reservoir as we go. Anything I need to be aware of with the ABS, or any other pitfalls before I start? As ever, any advice much appreciated. |
4th Jun 2015 7:17pm |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 247 |
YES that will work. I did mine that way a few months ago.. just on my own.
I had trouble using a vacuum bleeder, would not suck through.. some sort of restriction. Also struggled pumping with engine off.. so I started the engine and pumped up and down, worked a treat. 1953 80" 1987 mini city e 2011 90" |
4th Jun 2015 8:23pm |
Thanks for the replies. On the list of jobs for the weekend!
5th Jun 2015 5:13am |
