Home > Puma (Tdci) > accelerating in 2nd (and 3rd) - 2.2tdci |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
custom90steve, soon you will be able to add BAS2 Remote Remap Control tool to an existing non BAS tune should you ever need diagnostics
Pete Last edited by bell-auto-services on 2nd Jun 2015 5:27pm. Edited 1 time in total |
2nd Jun 2015 4:53pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20376 |
Pete, forgive my ignorance but what eactly is that? Is that live diagnostics your suggesting? Or are we talking fault codes?
2nd Jun 2015 4:56pm |
It's everything Steve.
Diagnostics fault codes, Live data, VCV reset, Injector programming, Pilot correction resets etc etc. basically everything apart from the remap as you already have one. Pete |
2nd Jun 2015 5:26pm |
Vintagepaul Member Since: 20 Jan 2015 Location: Rye, East Sussex Posts: 482 |
Pete,
Does the puma 2.2 have a specific map for the defender or is it the same as the one for the transit custom? The reason I ask is that I run a 2014 Transit custom DCIV with the 125ps engine fitted and I have noticed the same 'kangarooing' issues with that. It recently went into the Ford dealer for a software recall (would that be a re-map) and this has improved the kangarooing but I now get what feels as if the vehicle is surging on low revs in 3rd and 4th gears. I took it back to the dealers and they said that as the software has been reset the surging is a characteristic of the vehicle re-learning my driving style, does this seem likely or is he pulling my plonker? Cheers, Paul |
3rd Jun 2015 6:30am |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1581 |
Landrover must have changed a few things because my 12 reg defender used to hop about all over the shop. My 14 reg is fantastic works really well. A lot smoother and seems to pull better.
3rd Jun 2015 6:55am |
The SID208 engine ecu used on all of the models has the same issues in some shape or form exactley as to what I posted and explained was the problem earler in March this year back in this very thread. All the new "tuner" released smoothed out modifications and fixes seen as well as my own not excluding the new Autobiography 150 map is based arround the very same quirky areas amongst others I hilighted and so obviousley pointed out where the problem was lying with the calibration back then. This is no miracle fix they have mysteriously just come up with on their own they were handed the descriptive problem and needed fix on a plate to sort out I dont think it will be much longer before a genuine updates for Ford out too Regards Pete |
3rd Jun 2015 8:13am |
