Home > Puma (Tdci) > Radio and A/C Dies for a Few Seconds with Some Dash Lights
HardCharger
Hi All!
I encountered this issue on two separate occasions, venues, and times.
I'd be driving along then all of a sudden, the radio and the A/C dies and you'll see the park brake light, ABS light, and TC light come on for about a second or three then all will resume as normal. While all this is happening, engine power and drive are still proceeding as normal.
I called a friend of mine who works on Defenders and apparently I'm the 2nd owner of a 2.4 Puma to call in with this issue, the other guy is located in a different area than I am. The other guy noticed that for him, it happens in a particular area and has confirmed this by passing the area more than once with the symptoms occurring every time. He attributed his incidents to either a cel tower or a power node or something like that. In my case, I was not in the same area when both my incidents happened.
Anyone else experience this? Is there a fix?
Post #426282 26th May 2015 7:22am
HardCharger
Experienced this again today although slightly different happenings.
Was about to back out of the drive way so I started the truck up and turned on the AC, heard the condenser fan kick in but there was no air coming out of the vents. Tried the blower switch, no joy as well. Then I noticed the car charger wasn't lit so the entire center cluster had no power. Dash warning lights stayed off this time though. So I backed up the drive way and went to close the gate, when I get back, the car charger was again lit and power was restored to the center console.
I'm suspecting a loose connection somewhere as I think we maybe yanked something when we changed the bulb in the hazard light switch? We just pried open the center bit without disconnecting the other connections. I just want to run this by everyone to see if it's a simple fix or something more sinister is afoot.
The truck becomes an in-patient this weekend to have the cooling coil thermostat replaced so maybe once they put everything back together things will be OK?
Post #426787 28th May 2015 4:54am
munch90
maybe aux connection on the back of ignition switch
Post #426802 28th May 2015 7:44am
HardCharger
Thanks for the lead munch90, I'll have them check it out when they work on it this weekend.
Post #426992 29th May 2015 4:02am
munch90
or maybe ignition switch itself
Post #426998 29th May 2015 6:59am
Check the relays under the seat box, over time the wobble lose
Post #427005 29th May 2015 8:02am
HardCharger
Hi munch90, actually the ignition switch was checked a few months back and it's still in good condition so it can't be that though I'll tell them to look at it again.
Hi bpman, will give those a push then. Haven't done that yet. Thanks!
Post #427009 29th May 2015 8:07am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
Not a Puma I know, but I had a similar problem recently with my Td5 90, I eventually traced it to a loose earth connection between chassis and bulkhead, a number of system earth points come together at the bulkhead and I was getting a voltage drop across the bad connection.
Just a thought.
Post #427046 29th May 2015 10:23am
^^^^ I was going to suggest that too, earthing faults can cause all manner of weird happenings especially lights lighting up and all sorts.
An easy earth to access is the rear lighting earth strap on the transfer box, check that is tightened and a clean connection.
If you've had a clutch changed then it might well have been disconnected or worked loose it's self.
There is another on the the front chassis outrigger, think it's the OS but can't quite remember.
The tow socket if you have one may be worth looking at too but leave that until last.
I'm thinking earthing myself.
Thumbs Up
Post #427048 29th May 2015 10:34am
HardCharger
Thanks! Definitely worth a look at those places then.
Post #428254 3rd Jun 2015 7:14am
