![]() | Home > Puma (Tdci) > LTB00175 Clutch Master Cylinder Renewal |
Eduardo Member Since: 28 Aug 2008 Location: RegiΓ³n Metropolitana Posts: 2110 ![]() ![]() ![]() |
Here you have....
Technical Service Bulletin No.LTB00175 29 September 2008 Subject/Concern: Clutch Master Cylinder Renewal Models: Defender (LD) TD5 and Puma derivatives only. TD5 and Puma derivatives only. VIN-range: XA159810 Onwards Markets: All Section: 308-02 Summary: Methods engineers at Land Rover have recently studied the service process for renewal of the clutch master cylinder applicable to Defender TD5 and Puma 2.4D derivatives. Cause: The new procedure incorporates a slight change to the clutch pedal height adjustment. Errors in the original repair time have also been corrected. Action: Should it become necessary to remove/install the clutch master cylinder, refer to the new procedure detailed in Global Technical Reference GTR Workshop Manual, section 308-02. NOTE: Old labor time 33.20.01 Cylinder master renew 2.10hrs . Labour Time: Operation Description Operation No. Time New labor times Cylinder master renew (LHD). 33.20.01 1.6 hours New labor times Cylinder master renew (RHD). 33.20.01 1.5 hours Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
slocum Member Since: 16 Oct 2008 Location: Italy Posts: 19 ![]() |
Thank you very much!
