Home > Puma (Tdci) > Rubber plugs below the windscreen
gaijin
Switzerland
Hi
My 110 had two rubber plugs under the windscreen near where the vents were on previous defenders.
One has disappeared, leaving a square hole. Figure it's something needing replacement.
Did a search but no luck. Anyone know the part number?
Just curious but what is it for? Seem to recall that perhaps that's where the washer jets were on the td5.
Thanks
Post #426326 26th May 2015 8:46am
rustandoil
Cant help with the part No. but sounds as if you are on about the holes for windscreen wipers for right / left hand drive
Post #426327 26th May 2015 8:49am
stanley
Post #426333 26th May 2015 9:04am
gaijin
Switzerland
Yes! That's it. Looks a bit different but suits the purpose. Thanks
Post #426344 26th May 2015 9:16am
Fifth Horseman
That is the blanking plug for one of the wiring loom holes.
For the wiper spindle hole blanking plug you need LR014315
The round version is MWC2309
Post #426581 27th May 2015 7:19am
MartinK
maybe a good idea to empty a can of dinitrol cavity wax in the holes before replacing the bung Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #426828 28th May 2015 8:51am
