![]() | Home > Td5 > Rattling passenger dashboard |
Bonnet hinge shims Ray
rattlerboy Member Since: 23 May 2015 Location: county Posts: 3 ![]() ![]() |
Thanks for suggestion Ray
Just checked bonnet hinges inside and out and v solid - no sign of anything loose there unfortunately |
If it sounds like the rattle is behind the dash it could still be the hinge as it's hard to replicate when the cars not moving. If the bar that goes through the plastic shim on the hinge is touching the hook that is mounted to the body or looks very close then it could be the culprit Ray
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
My moneys on turbo heat shield
would that be because heat shield had become loose ?
can you suggest best way of seeing heat shield ? is it easily visible from engine area - above or below etc? thanks |
The bracket on the heat shield onto the back of the turbo snaps. Mine made a rattle that you'd swear blind was from the dash. Take it off and give it a test drive
