Home > Technical > Rear tub luggage/load eyelets
Screbble
Morning all, forgive the poor description!
I'm looking to source new/replacement eyelets fitted in the rear of my 90. You know the ones, the 6 metal loops fitted to the wheel arches at floor level.
I can't seem to find them anywhere. Ideally I would like direct replacements (I won't use the acronym OEM given the ongoing discussions on other threads!) but I don't mind upgrading/changing if it doesn't involve major surgery. Maybe a stainless steel option? Then again, maybe a H/D plastic option?
It's fully carpeted in the rear and the original eyelets are still in place, albeit very corroded.
Any pointers will be well received.
Cheers,
Will.
Post #425683 23rd May 2015 7:09am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
These from Paddocks...?
http://www.paddockspares.com/pm1096-tie-do...-of-6.html
Or just get them from local LR dealer.
Simon
Post #425684 23rd May 2015 7:20am
Screbble
Cheers Simon.
I should've gone to Specsavers.....
It would have helped if I'd searched using the correct terminology!
Nice one. Off to spend my well-earned pocket money........
Post #425688 23rd May 2015 7:31am
You often find vehicle converters selling this kind of thing on Ebay, when they've been taken out during conversion. I bought 20 from a Transit or similar, new take-off, complete with fasteners, for about a tenner.
Post #425697 23rd May 2015 8:33am
Screbble
You're not wrong there. I've had a look on EBay (using the right search terminology helps!) and there's loads of them.
Trouble is now - I've gone form not being able to find them to being spoiled for choice!
I've found the Landrover genuine parts at a decent price but if I put something that nice and shiny in there then the wife and kids are only going to want me to spend more pocket money on a shiny stainless rear cill/ seal strip, and then on shiny nuts and bolts for the seats.......
Strangely enough, and I'm not complaining, SWMBO seems to like these little finishing touches and she's making allowances with my pocket money. I'm not going to tell her that it's a Land Rover and meant to be a little scruffy!
I think Father's Day is coming up.....
Thanks for the pointers.
Post #425703 23rd May 2015 9:16am
If your vehicle is fully carpeted and these are heavily corroded then I'd be trying to find out where the water is coming in, has the carpet just helped to keep the area wet, is it ruined, is there any metal left to bolt a new one in through?
Give some thought to sealing the bolt on the wheel side, LR don't from new and it's just a leak path into the rear tub.
Post #425715 23rd May 2015 11:18am
Screbble
Yes, very good point. Thanks.
The tub/carpet is bone dry ( it's the rest of the truck that's leaking !!!) let me explain, as I didn't do it properly above. Confused
The previous owner had a rubber load liner with holes in where the tie down eyelets poked through. They obviously had water in there and/or hosed it out (poorly) over the years.
The carpet hasn't got any rust/ oxidisation stains around the eyelets (remarkably, and they are original) and the nut/bolts look ok too. It's the 'hinge' element of the eyelet that's looking worse for wear. Don't get me wrong, a bit of WD, a clean, and a spot of paint would do the trick, but if I can get new ones for a decent price I'd rather do that - and yes, I will ensure that the under arch work is waterproofed - as I know exactly what you mean about water ingress.
It's all good fun and there's nothing better than a good tinkering on a 'summer's day.' Cool
And yes, I am a bit of an anorak - most people wouldn't be bothered about this level of detail!
Post #425729 23rd May 2015 12:16pm
Djcla
Anyone know what the part number is for these, struggling to find the right terminology on eBay etc
Post #684057 4th Feb 2018 3:47pm
Screbble
I ended up getting mine from Rimmer Bros.
E0Z100000
£3.92 exc VAT each
There are cheaper on eBay as pointed out by others.
Thumbs Up
Post #684060 4th Feb 2018 5:01pm
