Home > Td5 > Top Hose Bleed Screw Snapped |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
Thanks for that
9th Mar 2012 5:05pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5699 |
Yes it is a common problem, and one that I have suffered.
When it does snap off the internal part falls in to the coolant system, which creates a lovely feeling of doom, but only actually only falls into the thermostat housing so can be reclaimed with the hose removed. Although that does not help much if you don't have spare screw with you. After my failure I carry spare top hose on my trips, but will now buy metal screw that you have mentioned above, and save some space. So thanks for the info, is the part number above for a standard replacement one, or metal one? I had to do temp fix with nut bolt, two penny washer, and some sealer between, far from ideal but worked. Andy Last edited by landy andy on 10th Mar 2012 9:03am. Edited 1 time in total |
10th Mar 2012 8:52am |
mudrut Member Since: 29 Feb 2012 Location: Stourport-on-Severn Posts: 80 |
Hi Andy
Fortunately, the way mine broke meant that the no bits fell in, but comforting to know that they only make their way down to the thermostat. Just to clarify; the part numbers I list are Land Rover original replacement parts. I found brass bleed screws on the web, but didn't note the suppliers or part numbers. kind regards Ian |
10th Mar 2012 9:01am |
Sorry just modified my post, as you were replying, but thanks for answering question.
Andy |
10th Mar 2012 9:04am |
LRSoffroad Member Since: 15 Feb 2012 Location: Doncaster Posts: 189 |
moust be the heavy handed Oaf with the screwdriver !!
10th Mar 2012 8:54pm |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 |
Anyone know where I can get my hands on such a metal bleed screw?
22nd May 2015 1:07pm |
think your find zone30 yours are a different bleed screw
think the ones there talking about are the smaller ones this is the one they talking about eBay item number: eBay Item No. 181698639028 but different to a tdci 2.4 |
22nd May 2015 1:13pm |
