Home > Puma (Tdci) > Clutch switch and throttle responce |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
Might this have something to do with the 2 different throttle settings.
High has little movement and low has full travel. Mike |
16th Oct 2008 8:05pm |
Landy nut Member Since: 22 Dec 2007 Location: In hiding Posts: 154 |
Is there anything like this that can be done to the TD5 and if so, how do I do it?? I am always trying to improve anything on mine until the warranty runs out, then I can do the other bits I want!!!
Thanks Landy nut |
16th Oct 2008 8:25pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8007 |
on a td5 the plug that goes into the top of the clutch m/c controlled the anti shunt, ie it held engine revs when you dipped the clutch to 'aid' smooth changes. in reality if you can drive its bloody annoying. disconnecting it stops this.
it seems from above that the it on the tdci it need to be disconnected and then the wires joined to effect the same mod. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
16th Oct 2008 9:03pm |
slocum Member Since: 16 Oct 2008 Location: Italy Posts: 19 |
On Tdci you can join the wires without disconnecting them from the clutch switch. I simply put a t-tap between them.
On Td5 engine you must unplug the connector from the clutch switch. |
17th Oct 2008 11:53am |
So what does this actually give you real terms? Mike
18th Oct 2008 4:01pm |
Now, when I close the gas, it actually closes immediatly. With normal setting, expecially in Low range, it takes a second before it actually closes.
18th Oct 2008 4:36pm |
Mine is instant to Mike |
18th Oct 2008 6:10pm |
Sorry to be playing to idiot card here chaps, but when you talk about closing and gas etc, I get lost.
Could someone give me in idiots terms, what benefit doing this would have to my TD5??? Is it s throttle response thing or it is a faster pick up thing or what?? Sorry to ask the obvious question, but I just dont get this one. Thanks Landy nut |
18th Oct 2008 6:40pm |
Im understanding it to be put foot on clutch to change up and the revs build whilst foot is off the go peddle and on the clutch Mike
18th Oct 2008 6:42pm |
I'm sorry, I assumed that you already known this practice on Td5 engine. Not so easy for me, but I'll try to explain.
In normal conditions, when the clutch pedal is released, the ECU, to avoid shoks to the transmission, has a very slow response to the stepping off of the gas. If you can drive, this slow response is really aimless and annoying, mainly in off road driving. When the clutch pedal is pressed, and this slow response becomes no longer helpful, the ECU cut the gas instantly. That's why many people use to disconnect the clutch switch on td5 engines. I apologise for my ugly english! I hope you understand anyway. |
18th Oct 2008 9:43pm |
I dont think the TDCi is the same Mike
19th Oct 2008 9:05am |
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 |
From the TDCi workshop manual:
"The clutch switch is located on the clutch master cylinder. The clutch switch is a pressure transducer type. When the clutch is depressed the clutch switch sends a signal to the ECM (engine control module) which reduces engine torque." Tim |
19th Oct 2008 9:22am |
mse, no, it isn't the same. Have you read the first post? On td4 (unlike td5, where disconnecting the switch is enough) you must shortcut the wires. The td4 switch is a "normally open" switch, the td5 switch is a "normally closed" switch. But this is the only difference. The behaviour of both engines is very similar.
19th Oct 2008 9:41am |
No what i meant was - i dont experience the symptoms of the TD5 on either TDCi's i had - so i dont think there is any point to messing around. Further - there is a difference in how the throttle response is on the TDCi against the td5 - as mentioned above, low has a different map on the throttle than high - so again i dont think there is any point Mike |
19th Oct 2008 11:29am |
