![]() | Home > Puma (Tdci) > OIL PUMP FAILURE 2.2 |
Gaz Member Since: 18 Jan 2015 Location: Midlands Posts: 29 ![]() ![]() ![]() |
Hi all having checked on topix (Jaguar LandRovers Diagnostics site)my 2012 90 has been actioned for a new oil pump.
I called my local dealer and yes they verified it is on the system for a new oil pump.Now what concerns me is its not a recall but what they call a oustanding campaing,so they will not send out recall letters as its not a safety issue,So if you do not get your vehicle serviced at a Land Rover dealer you will prob never know untill its too late!!!!! YOU HAVE BEEN WARNED CHEERS. |
Jonnie421 Member Since: 12 May 2015 Location: Wales Posts: 116 ![]() ![]() ![]() |
Do you know what models are affected !
Mine is a2007 tdci 2.4 ?? ![]() Too many other Discos to mention, including a V8 petrol Disco3 and diesel Disco 3 !! ( All gone) |
st86 Member Since: 16 Apr 2015 Location: Yorkshire Posts: 11 ![]() ![]() ![]() |
Is this oil pump failure problem a 2.2 problem i have a 2.4 can't say I've heard of many 2.4 problems
forest172 Member Since: 01 Nov 2012 Location: derbyshire Posts: 355 ![]() ![]() |
From what I've gathered MY12
2.2 problem different type/style to 2.4 one ( 2.2 is a viable displacment pump ) |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
Yes, it was an 'improvement' on the 2,2 to make the vehicle greener!
That's a relief then is there a fix for the 2.2s pump issue's
yes recall to replace pumps on some 2.2's
Defender-Stu Member Since: 14 Jun 2012 Location: South West England Posts: 1320 ![]() ![]() |
This has been covered, i have mine in the day my dealer was told so job done
![]() http://www.defender2.net/forum/topic36247.html http://www.defender2.net/forum/topic34986.html |
ParabolicSwivel Member Since: 13 Nov 2013 Location: Hertfordshire Posts: 42 ![]() |
Glad I read this thread! Called the dealer and found my MY12 is due this recall. Thanks for the info!
I do find it a bit disappointing that an issue that might wreck the engine like this doesn't merit LR or the dealer letting me know. Presumably cheaper in the long run to just replace a few siezed engines than make sure every vehicle is fixed. Ah well... |
Got mine done yesterday, new sump pan included,is it bigger or a different shape? Top service from Guy salmon Northampton.
