Home > Wheels & Tyres > Tyre options
Def Junkie
Tyre options
Hi, I've had a read through quite a few of the topics heer but didn't quite find what I was looking for. Hence the question. BFG, Coopers, Grabbers, MTs etc are not available in this nook of the world. My choices are Bridgestone, Pirelli Scorpions or Michelins. Any recommendations? Also trying to decide between 265 70 16 and 275 70 16 (slightly wider(10mm) and taller (7mm). Again grateful for recommendations.
Post #424735 19th May 2015 10:33am
K9F
Must be hard 'Somewhere In Paradise' try wrapping the rims in a mixture of palm fronds and coconut hair, soaking with coconut milk and palm oil and baking in the sun for three to four weeks on a quartz sandy beach. Work a treat and you can adjust the profile to suit!
Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #424740 19th May 2015 10:51am
Def Junkie
Rolling with laughter Rolling with laughter Thumbs Up
Post #424743 19th May 2015 10:58am
TJ101
Not 100% sure dubai is " 'Somewhere In Paradise" Question Question California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #424744 19th May 2015 11:00am
K9F
On a serious note it really depends on your intended usage. Bournemouth where I live we have the beaches, palms (no coconuts) but not the weather as a rule. If you were to be a little more precise about location without having to trawl through your previous posts, maybe someone could come up with a solution/shipping option to get you your tyre of choice.
You will never know! Bridgestone in my opinion/usage with limited options would perhaps be my choice personally. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #424745 19th May 2015 11:02am
Cupboard
I've got the Michelin Latitude Cross in 7.50R16 on my Defender and I think they're good.
Never had any scary moments on wet roads, in the dry I've stood as hard as I can on the brakes and had them squealing but only once had a bit of a skid. Off road, I've had them in thick gloop and you can tell you're not in a tractor but they've been good.
Edit: oh, and you can get them in the size you're after.
Post #424754 19th May 2015 12:03pm
Def Junkie
I am now back home in sunny Sri Lanka - a tropical isle in the indian ocean - was in Dubai when I joined the forum but that is another story.
Usage will be 80% tarmac and the off-roading will be mainly mud, gravel, river crossings etc. Not much sand driving at all. Shipping in to here is gonna be expensive and cumbersome with customs duties, taxes etc.
Post #424757 19th May 2015 12:07pm
K9F
Change of mind.....Michelins probably not your cheapest option but the best in your case. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #424759 19th May 2015 12:13pm
Def Junkie
Thumbs Up
Many tks. My choice as well. Any views on the size? 265 or 275?
Post #424958 20th May 2015 4:11am
K9F
Won't really make much noticable difference. Personally and it is a personal choice I like wide hence the reason I went for 305s. Naturally in your case 275.
Thumbs Up Cool If you go through life with your head in the sand....all people will see is an ar5e!!
Post #425040 20th May 2015 9:39am
Cupboard
Def Junkie: Is there a particular reason why you want the wide tyres? Narrow ones perform better for most purposes and are often cheaper. If you're not buying them locally, 7.50s and 235s are often available as new takeoffs.
Post #425080 20th May 2015 11:43am
Def Junkie
Mainly for the look. I like the wider tyres. Figured a 265 or 275 was not too over the top while giving a more sturdy look than the 235's I currently have.
Post #425267 21st May 2015 7:33am
Cupboard
Thumbs Up
Post #425312 21st May 2015 11:25am
leeds
I prefer 255/85/16.
A taller tyre then the 265 or 275 so more room under the diff. Being slightly narrower easier to steer at very low speeds.
Brendan
Post #425318 21st May 2015 11:54am
siwady
United Arab Emirates 2012 Defender 110 Puma 2.2 SW Sumatra Black
Hello Gents,
Thinking of buying Cooper St Maxx 265/75/16 for my 2012 110 Defender.
Any reviews on:
Highway Driving
Duna Bashing
Simple Rock Crawling (mostly gravely inclines)
and what's the biggest size I can go with on the stock rims without any modifications (no lift, no spacers etc...)
Post #426831 28th May 2015 9:02am
