Home > Technical > Rivet sizes |
Hi all, does anyone know the size of the rivets that hold the rear mud flaps on? I've recently lowered my 110 and with living in a hilly area I now ground the mud flaps regularly so want to raise them around 2 inches. I'm going to replace the rivets with stainless bolts but am unsure of the size I need, I'm guessing roughly m4/25 mm should be in the ballpark but wondered if anyone knew a definate size.
Cheers Ray Ray My build thread http://www.defender2.net/forum/topic17615.html |
18th May 2015 9:04am |
m6 and screwfix do some dome headed hex drive just right for job
18th May 2015 9:41am |
Excellent, I'll get some ordered and try and get them done this weekend
Cheers chaps Ray My build thread http://www.defender2.net/forum/topic17615.html |
18th May 2015 9:44am |
forgot to add screwfix ones are stainless m6x16mm or do 20mm as well
Socket Button Screws A2 Stainless Steel M6 x 16mm Pack of 50 |
18th May 2015 10:45am |
kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403 |
I get all my stainless fittings from an ebay seller called ABoltFromTheBlue. Reasonable prices and bolts, washers and nut are available in quantities of 5 upwards.
19th May 2015 6:24am |
