Home > Technical > New Battery for Remote
Page 1 of 3 123>
CatherineF
The Battery in the remote has gone, so we have bought a new one. Hubby went out to try it and it's not operating. Any ideas, please don't tell me it needs re-setting at a dealer. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed)
Post #424277 17th May 2015 7:54pm
grafty99
I think you have to repeatedly press both lock and unlock together until it does something Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #424283 17th May 2015 8:06pm
munch90
Just keep pushing the button til it works , sometimes 8 ish times just one button cant think if it matters which one
Post #424284 17th May 2015 8:07pm
Alien
Australia
The owners hand book has a section for the replacement procedure of the fob battery.
The gist of it is....
You have 5 minutes to do the change or you will need to enter the EKA code to synchronise the fob.
Procedure(basics)....
Insert key and turn to position II(ignition on).
Turn key to position O(Ignition off).
Remove the back of the fob and remove the battery.
Hold one button for minimum 5 seconds to drain any residual power in the fob.
Fit the new battery ensuring contacts are clean and polarity is correct.
Reassemble the fob.
From outside the car operate the LOCK button at least 4 times(this synchronises the fob).
Press unlock to unlock.
All done.
The above is from my Australian delivered unit but can't see why there would be a different else where.
I'd try doing the above before playing with the EKA codes.
Good luck and let us know how it goes. Cheers,
Kyle.
Post #424342 18th May 2015 4:21am
As above the LR one far more involved than others makes where you just change the battery and everything works!
Post #424483 18th May 2015 4:07pm
ericvv
I replaced the battery once myself, took all together less than a minute, and everything worked thereafter as before from the first click, did not have to synchronise anything at all.
Now tell me, the fob itself does not have a memory I presume, so it will not remember that it has been briefly battery-less during the replacement. Maybe the reason why it was so trouble free with me was because I did the battery replacement far away from the truck. So if the fob itself has no memory as I believe is the case, the truck will never know.
Makes sense?
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #424500 18th May 2015 4:39pm
stanley
Mine gets replaced at rather B service , I even get a reminder to take in the spare fob!
Post #424505 18th May 2015 4:58pm
Lorryman100
The fob needs to be re synced with the 10as whenever the battery has been removed. The reason for this is that each key fob that is learned to the 10as uses a rolling code as a defence against being cloned. When you remove the battery the fob loses this code and by pressing either button a number of times this re synchs the fob and 10as to the same rolling code. The number of times you press the buttons depends on how quickly the battery was replaced and whether or not another fob was used in the interim. FYI on the 10as 4 presses of lock is a full re synch as long as it has been enabled in the 10as settings menu with a diagnostic tool, (Plip presses for re synch)
If you look at the bottom of the below screen shot you will see that each fob has 4 rolling codes.
Post #424515 18th May 2015 5:35pm
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
Makes sense?
Eric
Never had to do anything other than press the buttons once or twice myself!
Post #424646 18th May 2015 10:13pm
Just remember that they are charging you somewher ein the region of £8.96 for the batteries and labour at £2.00 a minute to do it!
Post #424701 19th May 2015 8:22am
newhue
Australia
Um just wondering if someone has any further ideas. I have my immobiliser disarmed by land rover because of past headaches. I believe the alarm is still activated, and go goes off if a door is opened. I changed my battery today, well away from the car, and all within 1 minute. Of corse it did nothing when I went to try it.
So I have followed Alien's approach, and lorrymans, but still have nothing. I have no reason to think the replacement battery is flat, but I'm starting to wonder unless I have changed the 10as security system somehow. My Defender and travels
Post #456495 20th Sep 2015 7:58am
newhue
Australia
phew, you can all stop panicking. New battery was the answer, the old new battery must have been stuffed. Nothing fancy with the installation, just swapped it over sitting in the car then pressed lock a few times on the fob and hey presto it came alive. Good thing really, using the key to lock and unlock the drivers door, the only one with a barrel was becoming a pain. My Defender and travels
Post #457665 24th Sep 2015 6:49am
Djcla
Anyone know what type of battery goes in these fobs?
Post #683004 30th Jan 2018 8:40pm
Zed
CR2032 in mine.
Post #683007 30th Jan 2018 8:51pm
dorsetsmith
^ Thumbs Up
Post #683008 30th Jan 2018 8:56pm
Page 1 of 3 123>
