Home > For Sale & Wanted > [For Sale] 2 x Lightforce 170mm spotlights + wiring
dailysleaze
2 x Lightforce 170mm spotlights with a wiring loom. £100 posted
Both are working, and are currently wired to work independently with a separate relay and switch. You could wire them into the same switch if you wanted.
The relays were attached on the RH inner wing, with the loom stretching across the bulkhead face before splitting, with the switch wiring going through the LH bulkhead grommet to the centre console area, and the feed wiring going down past the gearbox to a battery compartment fuse box.
This is how they were mounted:
The switch location:
The relay and earths location:
Post #424247 17th May 2015 6:20pm
DOOFER
damn, if they were 140's id have your arm off. I already have 170's on the front and they are awesome, just not quite enough room inside the a bar for four of these bad boys DON'T PANIC
Post #424259 17th May 2015 6:56pm
chris d3
England 2011 Defender 110 Puma 2.2 USW Stornoway Grey
LF 170
May be interested in the lights mate where are you based
Post #424279 17th May 2015 7:55pm
dailysleaze
Bucks. I can post though?
Post #424282 17th May 2015 8:01pm
dailysleaze
Still available
Post #425997 24th May 2015 9:28pm
