Home > Puma (Tdci) > TDCi brakes dragging.
PAT303
Australia 1998 Defender 110 300 Tdi SW Alpine White
I'm a member on AULRO and two members are having problems with new TDCi's dragging their brakes,one owner is having the brakes drag bad enough it's heating up the rims.Has this problem surfaced in the UK?. Pat
Post #423952 16th May 2015 1:41am
munch90
I had it happen , but it was only because I had brake light switch out and it had got stuck when fitted back and was holding the pedal down a bit , pulled pedal up , loud click and all fine , checked lights working ok
other than that could be problem with
master cylinder
flexi rubber brake hose
seized calipers
pads seized in calipers
its worth getting it checked professionally being a brake problem
Post #423971 16th May 2015 7:39am
The only time mine dragged was due to a stuck piston in one caliper.
Post #423999 16th May 2015 10:04am
RED-DOT
Check the vent in the master cylinder is not blocked? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #424002 16th May 2015 10:15am
ozy013
Australia 2010 Defender 110 Puma 2.4 SW Rimini Red
"So they've fixed the issue. Apparently the brake switch was out of adjustment causing it to think the brake pedal was still being pushed causing the abs pump to stay activated and the brakes to hang on if that makes sense".
Just a quick update and also thanks for your suggestions. It seems the owner took it to the dealer and they pretty much sorted it straight away.
Thumbs Up
Post #428321 3rd Jun 2015 12:18pm
CarlS
2016 Defender 110 Puma 2.2 XS CSW Aintree Green
Ahhhh this is interesting, mine (2015 tdci) sometimes smells hot, I was thinking "is it the brakes?" but just put it down to the newness burning off.
The brakes sometimes squeek loudly when slowing down from 10 - 0mph slowly.
I drove it down to the local cafe this morning and on the way home I thought I heard the ABS kick in. Confused
Think I need to look into it a bit more by the sounds, I've only done 600 mile in the truck from new. The spawn of AndrewS
2016 Defender 110 XS Station Wagon (Built on the last day, 59 from the end) - Dead
2016 Mini Countryman Cooper S All 4
2019 BMW R1200 GSA Rallye Sport
Post #428329 3rd Jun 2015 1:02pm
AndrewS
What you need is my new infra red thermometer Thumbs Up 130's have feeling's as well you know Smile
Post #428384 3rd Jun 2015 5:09pm
CarlS
Yea it is Thumbs Up The spawn of AndrewS
Post #428428 3rd Jun 2015 7:45pm
PAT303
Thumbs Up
Hey,this is my thread,get your own Very Happy . Pat
Post #428483 4th Jun 2015 12:55am
ozy013
Hey Pat, oops sorry wont do it again Very Happy
Ian.
Post #428484 4th Jun 2015 1:55am
