Home > Technical > Axle diff vent hoses?
YOLO110
Australia
Hi Guys,
I noticed when I collected my Puma, that both the from and rear axle housings have what looks like a vent nipple fitted on the top of the casing, with a long run of 5-6mm black hose fitted to it. The hose runs back and up into the engine bay.
Is this a breather hose? I am confused as I have looked under quite a few other Defenders and not many have this fitted?
Was this an 'option' of some kind? I did not order it!
Sorry no pics... I am away from my car atm!
Cheers, Pete. YOLO... You Only Live Once...
Post #423976 16th May 2015 8:04am
munch90
sounds like standard fitment axle breathers
been fitted like that for many years ( think from when 90110/defender came out 1990 ish )
Post #423980 16th May 2015 8:08am
On my current Puma rear axle:
Don't think I've had a single Land Rover over the last 30 years plus that didn't have them fitted - although previous versions have bee better engineered than these.
Post #423986 16th May 2015 9:01am
In the early days (leaf spring era) the breather vented straight to atmosphere via brass doobrey on the tube. For the last two or three decades breathers vent via a tube to a high point.
Post #423998 16th May 2015 9:58am
martinfiattech
You might want to inspect the front axle breather hose, I found mine rubbed thru on the n/s/f front axle, suspension arm.
As luck would have it. The DAF truck dealer I work at have 5-6 mm air suspension pipes. these are a direct replacement.
A couple of push / quick fit connectors, and the front axle is water proof again. (well as best it can be). Excuse the spelling I`am better with spanners and wires.
Post #424033 16th May 2015 5:13pm
YOLO110
Australia
Weird...!
I have looked under quite a few new Puma's and not all of them have this fitted... Question YOLO... You Only Live Once...
Post #424049 16th May 2015 6:47pm
AndyTunn
New Zealand 2008 Defender 90 Puma 2.4 SW Stornoway Grey
Mine had the breather tubes from the front diff and transfer case running up into the engine bay, but the rear axle breather was just strapped up under the chassis. I took the plunge and routed all three to a dedicated "Nugget" manifold high up under the bonnet.
http://www.defender2.net/forum/topic34028.html
Post #426267 25th May 2015 11:29pm
