Home > Puma (Tdci) > Viscous Fan - Rotates Freely?
I can turn the fan by hand but notice that the resistance is variable, one part of the range it moves very freely and another part requires alot more effort - is that normal?
It may be an optical illusion but when looking from above the fan does not appear to be square to the shaft?
Post #423409 14th May 2015 8:43am
munch90
normally if you spin them by hand , they start to turn easier after short time of turning
Post #423421 14th May 2015 9:49am
Thanks, I played with it for a couple of mins but it didn't seem to change...
Post #423603 14th May 2015 7:56pm
Retroanaconda
Sounds the same as mine, which works fine.
Post #423640 14th May 2015 9:24pm
JOE_130
United Kingdom 2015 Defender 130 Puma 2.2 HCPU Java Black
That's perfectly normal. Our transit fleet of 20 are all as you describe Smile
Post #423756 15th May 2015 10:35am
Thanks for the reassurance chaps Thumbs Up
Post #423766 15th May 2015 11:23am
