![]() | Home > Puma (Tdci) > P1103 |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Below is a live data session after replacing the MAF sensor on my Puma. You can work out the curve based on rpm and load.
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 ![]() ![]() |
Just fitted the new MAF sensor. Andrew page £ 42.00 all in
![]() Once it was replaced I cleared the stored codes. Checked thru the ecu data list. The EGR valve is going nuts, the MAF is reading much quicker. I know the refresh rate on the snap on solus is`ent the quickest, But everything is measuring better / faster. On the short drive home the car is much quicker, especially in mid range throttle response. My values now reflect yours. However my EGR is still connected, how long it will carry on working now, it`s got something to do we`ll see ![]() While I write this the other half is looking some what dismayed at me watching a set of figures on a screen and getting excited by them. Many thanks for your time in posting the video clip, it`s going to be saved for reference. Thanks again martin. Excuse the spelling I`am better with spanners and wires. |
What make was the air flow you fitted ?
Hiya munch. Sorry for the delay. Been working all hours this week.
The maf is made by Hella. So far it`s all working ok, and my new friend the eml is a distant memory. I think a bosch one was 50 quid. There was a cheaper one for £25. But decided to give that a miss. Hope this helps, I`ve no idea now much Andrew page stock for the defender. But would assume most transit parts cross over to a point. All the best, off to bed... Excuse the spelling I`am better with spanners and wires. |
Ok , i know some of the cheap ones never give the right readings , think most fords run the same maf
