![]() | Home > Maintenance & Modifications > Mud New Convex Mirror |
CLCraig Member Since: 05 Aug 2014 Location: Somerset Posts: 104 ![]() ![]() ![]() |
Has anyone got a picture of them fitted? Many thanks?
trooper Member Since: 11 Mar 2014 Location: west sussex Posts: 102 ![]() ![]() ![]() |
Have just purchased a set (LH/RH) of the larger mirrors but cannot undo the existing mirror screws as they are seized solid. Don't want to damage the existing mirrors trying to remove the screws, as I may not like the larger mirrors when fitted, any suggestions how I may remove them would be greatly appreciated!
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17676 ![]() ![]() ![]() |
You could buy a pair of replacement arms, and leave the old mirrors alone on the old arms.
Non-genuine or take-off arms are not expensive. |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 ![]() ![]() ![]() |
Here you go, Not the best, but gives you an idea ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge [/img] |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5116 ![]() ![]() ![]() |
Love the Pipe holder.
![]() http://www.youtube.com/user/conwy1 |
Thank you. They don't look out of place at all thought they would be far too big
Thanks, the only 'real' accessory needed!! ![]() |
They're not as big as a lot of people will have you believe. At least I can now spot the audi/bmw ![]() ![]() |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello All
Interesting... I am looking at this for a different reason... ![]() Have recently bought an Eriba Van at 2M wide and have a need to ensure that I comply to the Rear Viewing Requirements, my initial thoughts were to swap over my existing mirrors onto a pair of Extend Arms. The Defender is approx' 1755mm wide, between the inside edges of the Standard Door Mirrors and the Mirrors themselves are approx' 125mm wide. So the overall width of the Standard Mirrors are under 2M 1950mm in my case with the mirrors angled in to suite my needs. For Towing the law states that for cars registered after 26th January 2007, towing mirrors must not project more than 250mm beyond the width of the Caravan (Trailer), so in my case the overall 'extended' door mirror width of 2500mm is allowed. (Eriba + 500mm) Whilst I know the Mud Blind Spot Mirrors are not designed as Towing Mirrors, they may still be of interest to give an increased Rear and Blind Spot View, probably still in conjunction with using the Extended Mirror Arms. Having now sorted out my towing frame I will set up and see how much of the Blue Triangle I get with the standard set up and work out a route to get all of it (or more). Main wish (beyond compliance) is to have a 'solid' set up, swapping over Arms is doable but there's more to when you actually look at it, Door Security on the top door hinge for a start in order to get to the Door Mirror Arm mounting screws Any thoughts, those who have sorted out there own set up... ![]() ![]() Click image to enlarge Towing Mirror View Requirements ![]() 2M wide Eriba 540 GT SKIP https://www.defender2.net/forum/topic83242.html |
take it you have tried with standard mirrors and measured what you can see ?
Hi munch90
No just about to, dragged this home with both the wrong towing arrangement (ball too high) and no adjustment to mirrors, but felt that the standard set up didn't restrict my view. Want to ensure that I avoid the 3 points on my clean license though... ![]() ![]() Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
The blind spots in my 110 Hardtop are large enough I lost our entire combine header and a trailer somewhere off to the passenger side yesterday. It's a good thing I knew it was there because if I'd just been relying on what I could see in mirrors we'd have had a bit of a crunch.
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 756 ![]() ![]() ![]() |
Hmm... After seeing these, they're apparently not as big as I thought they'd be. Looking forward to seeing one live before final decision. |
That was what was stopping me getting some but they don't look stupid from this pictures at all
