Home > Td5 > 110 Double cab to 110 utility hardtop conversion?
willyj
United Kingdom 2011 Defender 110 Puma 2.4 USW Stornoway Grey
As title suggests. I would like to change my double cab to a hardtop utility.
Is it doable? I was thinking of leaving the rear tub on as it's quite damaged around the mud flaps area and just getting a roof and the panel sides, back door also. Anything I might have to consider and how do I go about it with the log book?
Cheers wil
Post #421249 5th May 2015 8:21am
Quite feasible and, if you don't intend to change the rear tub, quite easy.
You will need to find a roof, the rear side panels (SIII 88" is an option here) and a rear door (it is virtually impossible to find a "cat flap" lift up flap for the rear now).
Your take-off roof, assuming that it is in good condition, will be worth more than you think, and certainly more than the replacement roof. If you are lucky, the sale of the DC roof will pay for all the panels you need.
Not sure how you stand informing DVLA, generally they don't seem interested in this sort of thing. They are more likely to be interested if you take an N1/light goods vehicle and convert it to something which falls into a higher road fund licence category though.
You will of course need to notify your insurer.
Post #421262 5th May 2015 9:44am
willyj
Cheers Blackwolf
Am I right in thinking that the side panels are just bolted on with a seal between it and the tub and likewise the roof?
Post #421265 5th May 2015 10:13am
Yes.
There may be some (minor) alterations required if you use SIII sides, I am not entirely sure. There are others here who have done this conversion, or who have converted SW sides into USW sides and no doubt will be able to advice in more detail.
It all just bolts together, however. The great joy of the current Defender - who knows if it will be true of the new one!
Post #421281 5th May 2015 11:33am
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
I did this back in the summer. Quite easy, liked the utility so much I then bought a new one Rolling Eyes so selling the double cab conversion. If you ever want a look let me know.
Post #423584 14th May 2015 7:10pm
