Home > Puma (Tdci) > dash rattle solved
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
dash rattle solved
just a heads up for anyone who may hear a loose tinny rattle in there dash, turns out that the socket that you plug in a computer watsit in (you know the one next to the fuses under the dash) well the torx screw that holds it in place had worked loose, and as sound does it travels and seems to be coming from just under the top of the dash, so a lucky find, hope this helps someone not go insane and rip apart there dash. Whistle
Post #41434 28th Sep 2010 12:06am
spudfan
Ireland
I found I get a squeak seemingly coming from the dash when the rubber inserts on the bonnet hinges get very dry. I squirt a little oil on them and that cures it until they dry out again. Happened with the Tdi too and the same thing solved that too. Might help someone. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #42124 6th Oct 2010 7:29pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Thanks for the tips Guys Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #42133 6th Oct 2010 8:07pm
