Home > Td5 > help td5 wont start |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 |
Could be the dreaded immobiliser.
It plays up on mine with similar symptoms. Turn ignition off for a while. Lock and unlock a couple of times with the fob. Try again? |
3rd May 2015 12:48pm |
eddiep Member Since: 14 Mar 2015 Location: lincolnshire Posts: 5 |
Tryed that been trying since 630 this morning
3rd May 2015 12:55pm |
Any 'unusual' and/or additional switches around and about? Under the dash/seat?
Could be an aftermarket immobiliser that could have been knocked? Ask me how I know! |
3rd May 2015 1:03pm |
Nothing that I can find driving me round twist was fine yesterday
3rd May 2015 1:23pm |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
Lift up the drivers seat and look at the relays under there. Wiggle them around and try again. One of them caused me a problem where the car would cut out and not start. I think it was a yellow relay on mine, related to the glow plugs...? Anyway, give them all a wiggle. They are liable to poor connections on the spade terminal.
The proper fix is to remove the relays and squeeze the spade terminals to make them tighter. There is a thread on here about it, will have a look for it. cheers simon |
3rd May 2015 1:31pm |
HansT Member Since: 25 Dec 2012 Location: Mariefred Posts: 173 |
I had this problem a couple of years ago and the solution was quite simple...
http://www.defender2.net/forum/topic17371.html |
3rd May 2015 1:32pm |
Did you get it sorted? |
3rd May 2015 9:26pm |
Tryed all day yesterday no joy went to it this morning put key in started as normal been fine all day now as much as I love it I am considering getting an older one with 300 TDI in thanks for all help and suggestions though
4th May 2015 9:44pm |
