Home > Puma (Tdci) > Defender Pedal Locks
Lorryman100
Found this on ebay, sent a message to the bloke asking when he will be doing one for the Puma Defender. Got a reply saying in the next month or so depending on when his mate will loan him his puma so he can size it! Anybody have one on their previous defender, do they work and are they worth £80 plus postage? Also looking to fit Mudstuff Mech lock but emailed them a year ago when i got defender and was told it would not fit on the bulkhead due to the bulk of the engine however it could be fitted into the cubby box, anybody done this? Question
http://cgi.ebay.co.uk/LAND-ROVER-DEFENDER-...2a0a22b124
http://www.mudstuff.co.uk/Meck_Lock.shtml
Post #42012 5th Oct 2010 8:35pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Re: Defender Pedal Locks
I asked the same question about 4 months ago and got the same reply still waiting ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #42022 5th Oct 2010 9:32pm
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
I have one on my TD5 and love it. It is very well made and very strong - not measured it but guessing at 4mm steel plate. It uses a very good padlock and has been made so as to fit very closely. It would be massive job to cut one off. I use mine every night and if I'm leaving the 110 for over an hour. My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #42056 6th Oct 2010 9:40am
Lorryman100
Update on Mech Lock
Got an email from mudstuff this morning saying that they now mount the lock body into the Ecu compartment under the drivers seat and use 3 meters of braided hose to run it into to the engine compartment to the clutch master cylinder. However they did not explain how they route it. Would there be any problems using this location in reference to the delicate electronics located there.
I did a little more research on the pedal lock and decided i want one! After reading the posts fekete and SiWhite put on here ive decided to pester the manufacturer with emails on a daily basis in the hope he gets his finger out and makes me one! Mad
Post #42060 6th Oct 2010 10:11am
SiWhite
In your emails, ask if he'll make one with a cover for the bonnet release lever - you can still open the bonnet with the lock in place. Seeing as the lever is right next to the pedal lock on a TD5 it would make sense to disable that at the same time... My blog - www.anacreinhampshire.blogspot.co.uk
Post #42076 6th Oct 2010 11:51am
Lorryman100
Good idea, would never have thought of that. Emailed and asked, will let you know the outcome.
Post #42170 7th Oct 2010 9:41am
fekete
I suppose i should start pestering him again he may pull is finger out if there's more than one on is case....good point si, on the cover for the bonnet release lever Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #42209 7th Oct 2010 5:58pm
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
If you put the lock across the bonnet release i dont think you would be able to fit the lock.
My lock slides in from the throttle side onto the brake pedal and can be a buggar to fit.
The extra length would make it harder to fit i think, i did think it would be a good idea too, but as all the scrotes just cut the cable and pop it open from outside the extra bit of lock would probabally be useless.
Post #42215 7th Oct 2010 6:42pm
talking of which, does anyone have a bonnet lock on their defender ?
Post #42365 10th Oct 2010 3:59pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
I spoke to mudstuff a couple of months ago about the mechlock and they basically told me that it was such a nightmare to route the piping around the puma that it would cost a he'll of a lot in labour to fit it (basically, they said, don't do it). I'd be interested to know if they've found a better solution. I'm up in hebden bridge in a few weeks - I'll pop in and ask them.
I bought the clutch claw as a pedal lock. It's a bit of a PITA. Lovely, simple concept just badly executed. The pins need to be 10mm shorter and the lock must use black magic to engage because I can never seem to replicate what eventually worked the night before. I think the quickest I've ever fitted it was 2 mins. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #42675 14th Oct 2010 9:40pm
i've got a clutchclaw - easy peasy to put on and off
Post #42680 15th Oct 2010 5:37am
Lorryman100
Mudstuff Mech lock
Got a reply back from mudstuff about fitting to a Puma:
Quote:
The handful of Puma devices we've fitted have been installed into the ECU compartment under the drivers seat which leaves the lock barrel coming out on the front face of the seat box. Sorry, I don't have any pictures.
We have had flexible Stainless Steel braided hoses made up to run from this mounting location to the clutch master cylinder and the flexible hose on the bulkhead. The addition of the braided hoses (3-metres!) unfortunately increases the price of the unit by £100.00.The pipework runs over the top of the bellhousing to the flexi-hose on the bulkhead and along the top of the chassis to the master cylinder so it is well protected.
We can normally install the device in a couple of hours. Labour rate is £35.00 per hr plus VAT.
So with the following prices: Meck lock system Defender kit £410.00 inc vat
3m Stainless braided hose £100.00
2hrs Labour £70.00
Total £580.00
I am still trying to work out if it would be worth fitting as theives can still tow the car away with the mech lock fitted and armed, and replace the clutch pipes to the master cylinder at their leisure! Confused
Also you can get the new Tracker Locate fitted at your home with a years subscription for £604.00
Quote:
Paul_1978
Ref Defender Pedal Lock,
Checked the bonnet on my Puma and cant see the release cable. Mind you if they want it open they would just use a crowbar anyway. Big Cry
Post #42699 15th Oct 2010 1:58pm
alantd
Re: Mudstuff Mech lock
2hrs Labour £70.00
Total £580.00
They've obviously figured it out then - good guys. That's not too bad I reckon. One that started out as a 2.4 TDCi 110 XS
Post #42880 18th Oct 2010 9:17am
mse
Come on guys - do you not remember, 90's and 110's didnt have bonnet releases inside, they had a barrel lock and a handle behind the grill...if you were desperate, then thats an option to retrofit?
But seeing no other car i have ever owned, bespokely locks the bonnet then its not at the top of my list! Mike
Post #43081 19th Oct 2010 9:06pm
fekete
Brian just ordered this from here...they have them in stock now...He will knock a £10 off if you ask Thumbs Up
http://cgi.ebay.co.uk/LAND-ROVER-DEFENDER-...889wt_1139 NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #61354 27th Feb 2011 9:34pm
