Home > Maintenance & Modifications > Mud New Convex Mirror
Page 1 of 3 123>
TDCi Guy
United Kingdom 1996 Defender 110 300 Tdi HCPU Auto Keswick Green
Excellent looking new product from MUD. Very useful for us hard top drivers.
http://www.mudstuff.co.uk/mud-blind-spot-mirror.html/ Tom
@tditomprice
100” Defender Hybrid
2010 Alaska White 90 HT
Post #420004 29th Apr 2015 5:52pm
rallysteve
Shame they only come in the larger 'dumbo ears' size mirrors! 02' 110 TD5 Double Cab Rebuild Thread
Post #420009 29th Apr 2015 6:09pm
leeds
Brendan
Post #420015 29th Apr 2015 6:21pm
Mo Murphy
My experience of big mirror heads is that the wind moves them so that eventually all you see in them is the road. Attempting to tighten them more to prevent this results in ripping the bottoms out.
I should point out this is with another make not mud's version but to be honest unless they've enlarged the ball mount wind resistance is going to push them back.
50 Shades of Pennine Grey
Post #420040 29th Apr 2015 9:09pm
Litch
I have been using the larger heads since the early 1990's when I first fitted a set to my 101FC (I also fitted them with heating elements at the same time).
In all those years and regardless of the vehicle they have been fitted to I have never had a problem with them moving, I have found that it is just a case of making sure they are correctly fixed in the first place.
I should imagine that if you have a problem with them moving then you could just drop a spot of something on the ball to stiffen them up?
+1 for the blind-spot offering from Mud.
I have fitted my own stick-on convex mirrors in the past but these look excellent. ONE LIFE, GET IT!
Post #420229 30th Apr 2015 5:32pm
Cheshire110
as above, wish they did a normal size variant! defender mirrors are already big enough Cheers, David
Post #420248 30th Apr 2015 7:06pm
munch90
+1^^^ , would prefer standard size
Post #420265 30th Apr 2015 7:41pm
leeds
One of the first improvements we do is fit larger mirrors. It is good for us as we tow on a regular basis plus drive on the continent . We have not experienced any problems with wind on the mirrors.
Brendan
Post #420275 30th Apr 2015 8:10pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
I have to agree, if these mirrors were standard size I would buy them straight away, as it is I have just fitted small circular blind spots onto the standard mirrors because I couldn't find anything else suitable. The standard mirrors are already big enough.
Post #420280 30th Apr 2015 8:23pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Far too big for me.
As for driving on the continent or in the UK, you'll always have blind spots. In both cases I just anticipate and in at t-junctions for instance, I simply don't steer in directly but go straight till I need to go left or right. Solves the problem for me. Whether with or without a trailer.
Post #420408 1st May 2015 11:55am
HardCharger
I find that the standard size mirrors are good enough though I think I have convex mirrors fitted to both sides? In any case, if this kit came in the standard size then I would also consider the upgrade. I have to admit though that I haven't seen any truck thus far fitted with the larger mirrors so I may change my opinion once I see one.
Post #420995 4th May 2015 3:50am
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
Bought one for the driver's side, rhd.
Not great in my opinion. Problems are:
1. The new mirror plate is just too big for the housing it sits in, doesn't seat very well and therefore vibrates even more than the large mirrors do anyway.
2. The optics of the two mirror components do not line up and therefore you don't get the same visual point of reference. As Mud say the two parts are not separately adjustable.
This means if you set it up so that the main flat part gives you a view say, of the edge of the car, the convex bit gives a view miles further out, which sounds OK but in reality is weirdly disorientating as you've got no point of reference in relation to the vehicle.
I checked in my Vivaro van which has two parts mirrors and they don't vibrate and they do line up on the car-side edges.
Mud gear is usually good but not this time I think. And they're a hell of a price for what they are. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #420999 4th May 2015 5:15am
Macpaul
Actually, I got that wrong, having now driven the thing again.
If the flat section lines up with the edge of the car, the convex bit gives you a big view of the car itself and doesn't go far out into the road.
Same basic problem though. 2003 Td5 110 Hardtop
Post #421063 4th May 2015 1:35pm
munch90
Sure you not got it on wrong side , they do left and right ones on muds website , just a thought ?
Post #421072 4th May 2015 2:34pm
smb
^^^ as Munch said. Put mine on today and they are brilliant. My old ones wobbled around a bit at speed, but these stayed as tight as...
Angle of view for both upper and lower mirrors were excellent for both left and right.
I can imagine that you need to take into account eye level height and angle in relation to seat height, angle and how far back the seat is and also angle of mirrors and mirror arms, etc, etc.... But does the job just right for me Thumbs Up
Post #421384 5th May 2015 5:59pm
Page 1 of 3 123>
