Home > Maintenance & Modifications > Towbar modification? |
That's what I did with mine, it looks slightly different as mine's a Dixon Bate version. I think that it is actually stronger with the original drop plate behind it giving it extra rigidity to any sideways movement.
Click image to enlarge |
28th Apr 2015 9:43pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
The holes won't line up but you can drill em
28th Apr 2015 9:44pm |
Plus you get to not have to find a new position for the 12N socket and keep the loops that the breakaway cable pass through. I allways find it amusing when people drop the breakaway cable over the tow ball as if anything is going to fall off then it is more likely to be that and the cable goes with it
28th Apr 2015 9:46pm |
Honcho Member Since: 08 Mar 2014 Location: ^^^ Posts: 49 |
Makes no sense at all JWL, some people are stupid!!
I was thinking that it shouldnt be a problem all right. Could even stick a weld on it too for overkill |
29th Apr 2015 12:35pm |
