Home > Puma (Tdci) > Brake and reverse lights not working
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
I noticed that my break and reverse lights are out. Fuses are fine. Where to fault find next? Are these light going through the same connector?
Post #419143 26th Apr 2015 12:06pm
K9F
Is your high level and numberplate light also not working? They have different earths so it sounds like a supply issue.
Check the supply at the lampholders with a multimeter using a different confirmed earth. The only common factor is the supply to fuses 13 and 14 which is a single feed up to this point then splits. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #419146 26th Apr 2015 12:22pm
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
Btdt, back numberplate light tends to have water issues resulting in other lights not working, though don't think it influences the brake and reverse light (if I remember correctly)...
Post #419148 26th Apr 2015 12:26pm
Marius
Re: Brake and reverse lights not working
Rear lights, for headlamps, are working.
Do I access the lights from the outside or inside?
Post #419152 26th Apr 2015 12:34pm
K9F
Outside. Undo the two screws and gently pull the light out. There will be a connector on the rear. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #419153 26th Apr 2015 12:36pm
bga86
2015 Defender 90 Puma 2.2 HT Fuji White
First thing I would check is the bulbs. The high level can fail to work because of contact problems on rear screen, it is also possible both lower bulbs have popped. Reverse light not working may be switch issue.
Post #419223 26th Apr 2015 4:52pm
Marius
Still didn't have time to check the bulbs. It's a bit of work since I have covers over the lights riveted on. Number plate light is working.
Post #419363 27th Apr 2015 8:52am
JWL
Have you got a trailer socket fitted? If so plug a trailer light board in and check if they're working. If so then it's probably an earthing problem that may be sorted by undoing the corner panels from inside as the loom, if I remember correctly, feeds the multiplug under the offside rear wheelarch first before the vehicle lights. If the problem is still present with the trailer lights connected then the problem is closer to the source of power to the switches, ie fuse or broken wire.
Post #419365 27th Apr 2015 9:04am
Marius
Trailer lights not working either
Post #419442 27th Apr 2015 1:17pm
JWL
Pointing towards the switches then, might be well worth looking up on t'internet for the locations of the plugs on the loom as with both not working it'll be likely to be a poor connection where the wires join into the loom or some wire damage in the vicinity.
Post #419447 27th Apr 2015 1:44pm
munch90
the joint (plug and socket ) for the rear part of the loom is under bonnet beside the clutch master cyl (rhd )
Post #419454 27th Apr 2015 2:27pm
Marius
But........ Reverse Light also not working.
Post #419823 28th Apr 2015 6:40pm
newhue
Australia
Hey did you eve get to the bottom of this. I have no Reverse lights but everything else is working. Checked fuse all good, sniffed around the gear box looking for a loose plug or fitting. No luck. My Defender and travels
Post #422356 10th May 2015 10:19am
Marius
Yes I did. The brake light fuse kept blowing. In the end i opened the unit, but the bulb was fine. Upon closer inspection one of the spring connections to the bulb broke off and shorted the brake to the headlamp connector. Same happened to the reverse light but no fuse blown for that one, only the spring pin fatigued and broke off. New plastic housings and all are fine!
Post #422397 10th May 2015 1:59pm
